Reply 7580 of 30567, by derSammler
wrote:Apparently Opti ISA Chipset 82C931 aka "Opti Audio 16" isn't even a 16-bit card. It's a Soundblaster Pro 1.0 (not 2.0/Old) clone. Weird considering I was under the impression that it was a SB16 clone.
There are no SB16 clones apart from some ALS and CMI sound chips.
The 82C931 does 16 bit using WSS, just like most other cards from that time. Also, it's certainly NOT a SB Pro 1.0 clone, as then it would do stereo FM using two OPL2s.
