First post, by noshutdown
The attachment unidentified386.jpg is no longer available
this 386 board looks generic huh? soldered 386dx-40,opti chipset, 8 simms, 128kb cache and fpu socket, all in a very typical compact layout. but there is no brand or model marked so i can't find info on some jumpers.
green marked ones are what i can find: fsb(printed on board) and external battery.
but several jumpers marked in red still remain unidentified, can anyone with similar boards tell me what they are about?
the one near battery is probably cmos clear, but i dunno which pin is normal and which is clear.
Reply 1 of 3, by luckybob
well, its not 100% helpful but...
http://stason.org/TULARC/pc/motherboards/U/UN … 86DX-33-40.html
Reply 2 of 3, by blurks
Could also be a BEK-TRONIC BEK-3739 although the chipset is missing in the drawing (but mentioned in the description).
Reply 3 of 3, by CkRtech
Good luck with the ID work. Wincing at the leakage there. Looks like it is on half your AT PSU connectors in addition to those caps. Can't tell from the resolution/lighting, though.
