Reply 440 of 1539, by SpeedySPCFan
- Member
wrote:It would be good if you note in the description which games are represented in a too slow speed due to the 60 Hz.
Out of every game I've tried, the only one that ran too slow was Descent. Gameplay seemed okay but the music was being played back at a much lower tempo. I haven't tried Descent 2 to see if it's the same way, but I wouldn't doubt it has the same problem. Maybe we should start a community-sourced list of games that are compatible and incompatible with VGA240?
edit: Actually, Descent runs just fine. I remembered the music being faster, but I compared it at 70hz to how it sounds at 60hz and it's the exact same. Weird.
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
