Most frustrating part of working on old computers?
Reply 80 of 167, by Dracolich
Same here, derSammler. Just a few days ago my secondary slave, an 18GB Maxtor, started making those dreaded knocking sounds. Fortunately it was still empty so nothing is lost. I dug an ATAPI Zip250 out of my closet. I remember many years ago when I found it at a thrift shop for $3, already mounted on a 5-1/4 bracket. 😀
I installed that onto the secondary slave, put GUEST.EXE in my AUTOEXEC.BAT, and good to go. I still have 5 zip100 disks and a portable USB ZIP100 , so transfers won't be a big deal now. When the CD-ROM and 3.5" floppy were the only removable options for this machine I didn't like the idea of CD for transferring everything bigger than 1MB. Too wasteful of CDs ...
Reply 81 of 167, by Pabloz
reinstalling windows?
even in the 90s i used norton ghost in DOS
best thing ever. after you setup win98 you take an image and it is very small
from there you can change videocard, install other drivers. and you can go back if something bad happens.
Reply 82 of 167, by liqmat
Basically spending money just to frustrate myself and call it a passion. 🤣
Reply 83 of 167, by Artex
Oh where to begin...
Buldging caps
Leaky Batteries
No documentation
No "try before you buy"
Transferring anything to and from them
JUMPERS
Lack of PS/2 (varies)
Lack of native networking
Processor pins!
Troubleshooting issues
IRQs/DMA/Addressing
Bus speeds & dividers (or lack of)
Constant worrying!
Reply 85 of 167, by JoeCorrado
tayyare wrote:
You just finished a project. After days after days of working (collecting parts, making neccessary repairs, finding more parts, finding all the drivers, then finding better parts and also their drivers, installing everything and troubleshooting along the way), everything is shipshape and working as expected or better. Just then, as a stupid impulse, you think you need to "improve" some trivial thing. Like a Geforce 4400, instead of a 4200, or a SB AWE64 pro instead of a SB AWE64 value. While trying to make your absolutely needed(?) "improvement", something essential dies....
I hate it.
Yep. Been there, done that. LOTS of fun! 🤣
1. I am going to say that my biggest issue with retro computing is just the crazy prices asked for what would have been a minor component, worth just pennies, back in the day.
2. Or like somebody else mentioned, finding that the part that you never ever expected to need when you traded or gifted it a week ago, is suddenly just what you desperately need this week! Now, refer back to my complaint on pricing to replace this item above.
Oh, yes... the joy we have! Only exceeded by the satisfaction we get when a build comes together!
-- Regards, Joe
Expect out of life, that which you put into it.
Reply 86 of 167, by luckybob
shipping costs...
Reply 87 of 167, by probnot
Munx wrote:
Molex power. I'm getting tired of using pliers to swap drives and cards.
For the life of me, I don't remember molex power connectors ever being difficult to disconnect.
Reply 88 of 167, by cj_reha
Going to the thrift store and spotting a really nice old beige case with old looking drives, getting high hopes, then opening it to find the previous owner upgraded it to a boring socket 478/A/etc board... 🤣
Reply 89 of 167, by cyclone3d
I hardly ever see old systems at thrift stores anymore. IF I do and it has a case I like and it is super cheap I will snatch it up.
If it looks old and is not super cheap, I open it up at the store to see what's in it.
Always carry a screwdriver with you.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 90 of 167, by cj_reha
cyclone3d wrote:
I hardly ever see old systems at thrift stores anymore. IF I do and it has a case I like and it is super cheap I will snatch it […]
The place where I find most of the stuff has a flat $10 per untested or "old" tower, so I usually pick it up for the case, if not for the hardware inside.
Reply 91 of 167, by Munx
It varies from device to device. The most stubborn connection I had to deal with so far was on a Radeon 9800 pro.
My builds!
The Underdog - The budget K6
Reply 92 of 167, by liqmat
You will if you ever get an early 80s or late 70s computer that hasn't been fiddled within 40 years and the molex connectors have stayed untouched. They can be like cement when trying to pull them out. I've cut many a finger trying to pull them out when they suddenly give way and my fingers go banging against sharp metal case edges.
Reply 93 of 167, by brostenen
looking4awayout wrote:
brostenen wrote:
There are ways around that. USB-to-Pata dongles, so you can connect old harddrives to a modern computer. Or usb floppy drives. Usb cd burner and a CD-RW disk. CF card reader and CF-to-IDE in your retro machine.
Lots of ways to transfer stuff. Just be glad you do not have to set up a stock Amiga 600 (1mb Ram), KickStart 37.300, with no data on the harddrive, and not having any workbench disks.
That is a really tricky task...
I don't need all those things. I'm setting up my Pentium 3 to be usable as an everyday system and I'm actually succeeding at the task. It's however frustrating to find out that only two out of ten 512MB PC133 sticks are working without errors.
At the moment I run the system with the main WD Velociraptor hooked to a SATA to IDE adapter, and the data one to a non bootable VIA VT6412 SATA RAID controller. Now if there is a bootable PCI controller compatible with the Velociraptor, I would have a very fast Pentium 3 machine, even though it's already very fast and usable as it is now. A fast hard drive and graphics card does really make a difference.
Yup... Thats were we all, are different. 😀 😀
Personally I need my Amiga/C64/AT/ATX stuff. It was part of my childhood. So for me, 80's computers are a normal thing wich I have seen, used and seen others use back when it all was the new wild high end stuff.
Yeahh... These days I realise, that it is not going to be long time, untill I can sit with another person and talk about those darn teenagers that know nothing. And tell them that back in my days, we did it the hard way, by actually writing commands and we had to walk one hour in bare feets, through the wet potato field, in order to buy a game.
Got off my lawn you teenagers, I am enjoying my cold limonade here. 🤣 (while I put my fake teeth in)
Reply 94 of 167, by harddrivespin
Amiga... Keep that! They're nigh impossible to find for good prices save thrift shops or dumps.
Reply 95 of 167, by tayyare
Ahhaa... That's it! 🤣 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 96 of 167, by jaZz_KCS
Get a new (old) computer. say to yourself it's really worth it. Good price. Will work without a hassle.
One week later..: Still fiddling around with what should have been a one-afternoon deal.
Frustration ensues.
Reply 97 of 167, by brostenen
Expensive?? True that... So far, I have spend some 320 US Dollars on my A600. And that is the machine it self, not counting in external drives, mouse and other stuff. It's the unit it self, making it run stock configuration. I bought it, and had to upgrade the kickrom, and it needed a complete recapped systemboard as well. For me to even have such a machine, then I had to sell off one K6-2 500 machine and a P-II-400 machine. Plus one of my AWE64-Gold's.
Yes.... They are not cheap at all.
Reply 98 of 167, by Artex
gdjacobs wrote:
Maybe Artex will use his MPU-401 cards for captive mating purposes and share the offspring with the rest of us. 😀
Reply 99 of 167, by bjwil1991
I purchased an external parallel port Sony StorStation Ditto 2GB that needs a new rubber cap for the tape motor (that spins the inner tape cartridge wheel left and right) since the one that was in there disintegrated due to the high levels of humidity or heat, and the one tape I had for my Conner internal tape drive got eaten and was raveled inside of the cartridge (thankfully) due to the tape getting sticky goop on the wheel from the external tape drive.
Where do I find parts for that?
