Path: bga.com!news.sprintlink.net!uunet!in1.uu.net!jaxnet.jaxnet.com!jax!rbourne […]
Newsgroups: comp.sys.ibm.pc.soundcard.tech,comp.sys.ibm.pc.games.action,comp.sys.ibm.pc.soundcard.misc,comp.sys.ibm.pc.soundcard.games
Subject: Re: Do SB FX crash your system?
Followup-To: comp.sys.ibm.pc.soundcard.tech,comp.sys.ibm.pc.games.action,comp.sys.ibm.pc.soundcard.misc,comp.sys.ibm.pc.soundcard.games
Date: 13 Mar 1995 22:34:00 GMT
Organization: JaxNet BBS (904) 292-4567
Lines: 18
Message-ID: <3k2h8o$4h8@jaxnet.jaxnet.com>
References: <D3vIx7.2xr@freenet.niagara.com> <3hlb8h$ian@newstand.syr.edu> <3hs9c6$plc@grissom.powerup.com.au> <3ia3u2$t1r@sun.rhbnc.ac.uk> <3ial9q$djq@decaxp.harvard.edu> <3j1kta$3np@sun.rhbnc.ac.uk> <3jee43$i3m@woodstock.socs.uts.EDU.AU> <3jo04a$g0n@fantasy.barwonwater.vic.gov.au>
NNTP-Posting-Host: jax.jaxnet.com
X-Newsreader: TIN [version 1.2 PL2]
Xref: bga.com comp.sys.ibm.pc.soundcard.tech:9486 comp.sys.ibm.pc.games.action:65813 comp.sys.ibm.pc.soundcard.misc:6514 comp.sys.ibm.pc.soundcard.games:5516
Rex Foord (r...@barwonwater.vic.gov.au) wrote:
: I too have been having problems with a SB16 card purchased as
: part of CL's multimedia CDROM kit.
: I runs the diags ok, seems to work ok in windows, but dos games
: are having a real hard time. In some games only the sound FX
: works and no music, or its the other way round.!! I have tried
: various settings ie differing irq's, dma etc, have changed video
: cards (from an S3 to a ts et4000) booted up with a bare bones
: system, no drivers etc. All to no avail.
I had the same problem. I read turning off the cache would allow it to work.
No good. I played around with the other settings and found turning on
"hidden refresh function" (defaults to off) cured the problem.
Lot's of luck
Rob
