First post, by Cobra!
- Member
I'm trying to install a CD copy I have of Half-Life 1. However, the installer doesn't run at all, no errors, it just does nothing, nothing appears at all, and I need to go to task manager to close it.
I've tried copying the CD contents over, and replacing the installer (since it's 16-bit InstallShield) with a 32-bit version, but that didn't work either. I got the same results.
I've already tried redeeming the CD Key on Steam, but that didn't seem to work, it says it was already used.
What do I do?
