Windows ME build
First post, by PcBytes
I've did several XP machines, a 2003 one, a 98SE one (which is still in use btw), a 2000 one but I realized I didn't have a ME one.
With that being said, here are the specs:
JNC RJA-52 case
LC-B350ATX PSU (with strong 5v rectifier, recapped)
Epox EP-8RGM3I - nForce 2 IGP
256MB DDR400 RAM
AMD Athlon XP 2500+
nVidia Geforce 4 MX440-8x 64MB AGP8x - golden PCB
Liteon DVD-ROM
Winfast TV2000XP Deluxe/BT878 TV Tuner
40GB WDC WD400BB HDD
and of course, Windows ME 😀
Reply 1 of 13, by dr_st
It's gonna be like taking some aspects of 98SE and some aspects of 2000. The best of both worlds or worst of both worlds? You decide. 😀
Reply 2 of 13, by PcBytes
Heh, I've already used ME before. It's been pretty stable for me on every hardware I've used it - Pentium MMX, Pentium II, Pentium III and a Duron 950MHz.
The only thing I don't really like, but can live without, is the removal of real-mode DOS.
Reply 3 of 13, by Srandista
You can bring it back 😉
https://web.archive.org/web/20070808002732/ht … me/real_dos.htm
Reply 4 of 13, by Azarien
And then some DOS tools and drivers still didn't work because they were scared by DOS version 8.0, or because IO.SYS did strange things (e.g. integrated HIMEM.SYS if I remember correctly).
Reply 5 of 13, by chinny22
I was the same, even back then No dos mode = not on my PC's. Even a simple boot disk would get you into dos if you wanted but why should I have to!
I was going to runup a WinME PC over Christmas but lost interest even before I started, it holds no interest/nostalgia for me whatsoever.
Still if it gives you an excuse to runup another PC then happy days!
Reply 6 of 13, by LHN91
For me, if a machine won't be playing DOS games but needs (or I want) a 9x operating system, then I always go ME.
It's a convenience thing - more stuff integrated (USB, Zip Folders, it seems to not need the install disk nearly as often as 98SE) and so the setup and day-to-day livability is better, at least for me.
My in-law's retro LAN is all ME machines, as they don't tend to run DOS stuff (most of the machines are ISA-less P4's and Athlon 64's) but the main game they want to play, Outlaws, isn't fully functional on any NT kernel.
Reply 7 of 13, by derSammler
Who cares as long as you can load a mouse and cd-rom driver? That's all you normally need to play DOS games. If tools don't run because of DOS version 8, then there's a good reason for it. Better they are "scared" than f*cking up your hard disk.
Reply 8 of 13, by bregolin
Right on. I've done the same with my Compaq n1000v - does not support Win98/ME officially (drivers are XP and up) but I managed to grab the proper non-OEM drivers and got it to work perfectly with WinME. Since it does not have Sound Blaster emulation, I can't do pure DOS gaming, but I can play whatever games can be run from within a DOS box.
IBM Aptiva 2162 - P55 166 MMX, 32MB, CS4237B + Wavetable, ATI Mach64 2MB / Win98SE
Custom PIII 750, 64MB, SB AWE64, Voodoo 3 3000 AGP / Win98SE
Sony Vaio z505 SuperSlim - PIII 550, 192MB, YMF744, NeoMagic 256AV+ / Win98SE
Reply 9 of 13, by PcBytes
Meh, I ran 98SE on a Acer Travelmate 804, which is a Pentium M.
Had most of the drivers preinstalled (HDD came from a dead Fujitsu-Siemens Amillo P4 laptop) since the GPU was a Radeon 9000 Mobility and the rest was pretty much supported. If there's one thing I couldn't use since 98 was too old (I think that maybe ME had support for it tho, not sure about that) was Wireless capability.
I finally gave it to a friend who installed Linux Mint and uses it as a jukebox through Youtube in his flower shop and he gave me a Acer Aspire 5349 which just needed a new HDD. (the old one was toast)
Reply 10 of 13, by Errius
You can use a boot manager to dual boot DOS 6.22 and Windows ME (or even Windows 98 and Windows ME).
Is this too much voodoo?
Reply 11 of 13, by derSammler
If you need/want pure DOS, just don't use Windows ME. Most DOS games run fine from within ME anyway. But really, ME is very nice for Windows games that fail on XP, or if XP is too slow on the hardware. If DOS is important, 98 SE is a better option.
ME has at least two advantages over 98 SE: it boots and shuts down *much* faster, and it has a working USB stack without having to install any hacks like you have to for 98 SE. Also, the GUI has many little tweaks that make it feel more modern.
Reply 12 of 13, by clueless1
I like ME over 98SE on a late '99 to '02 system build. I've got 98SE on a P2-400 system from 98, but even there, I don't really run any DOS games on it. I have a 486 and P55C that are pure DOS. That's how I roll.
Reply 13 of 13, by PcBytes
Well, sad news - the EPoX board died - a fuse near the NIC ports blew along with a ferrite bead. I replaced the fuse and still no POST.
Fortunately I replaced the board with a MSI K7N2-L that works.
Possibly I may be able to bring the board back by bypassing the component altogether with a wire (it connects two traces on the board) and testing.
