Reply 40 of 151, by appiah4
No intel cpu since and including the Pentium Pro is safe to use unpatched.
They just did not report on earlier models because they are obsolete, so they did not bother to test (or report).
Reply 41 of 151, by Azarien
Core 2 may be old, but still perfectly usable for many tasks. Far from obsolete and better than many later chips like Atoms.
Reply 42 of 151, by appiah4
Take it to Intel, I guess 😎
Reply 43 of 151, by Scali
I wouldn't be too sure about that. I'd like to see a proof-of-concept being executed successfully on each CPU first.
There is a difference between the CPU using speculative execution and it actually being exploitable as a side-channel.
The window has to be large enough, and the differences have to be large enough to make reasonably accurate measurements.
Reply 44 of 151, by spiroyster
Itanium and early Atoms don't suffer it (but who uses them?).
What this means for older hardware is that, pre Win7, there will be no 'official' patches, so basically any old OS (9X, ME, 2K, XP, Vista, unpatched old linux distros) and old hardware shouldn't be online (or at least don't keep sensitive info that you don't mind loosing on it). It's probably ended the use of a lot of these systems as daily drivers for people who still use them, but then again these systems can't be kept up to date (no patches, updates etc coming their way) anyhows so do people that use these as daily drivers care? who knows. It's not like this is the only security flaw that these old machines/OS suffer from which will never get patched though, although this one is fairly far reaching since the scope of the effected systems (pretty much most consumer CPU architectures in the last number of years at least).
People seem to think this is an Intel only problem... It is not... while Intel suffer Meltdown (and bad PR), AMD, ARM, POWER...all suffer Spectre.... so thats like every iPhone/iPad that exists and most (if not all) android phones o.0.... or put another way, anything that can play a youtube video at 'enough' quality thats worth it these days.
Reply 45 of 151, by dr_st
So far this is just FUD. Let's see one single working exploit in the wild, that actually manages to leak anything other than hand-crafted examples. You know what would happen if something like this existed? Microsoft would release emergency patches for XP and Vista as well, just like they did for XP with WannaCry.
Both points are correct. (1) It is not the only flaw and (2) people who feel sufficiently safe with these old unsupported systems at this point, will probably continue feeling just as safe even given this latest vulnerability.
Reply 46 of 151, by appiah4
Just because you do not know it exists doesn't mean it doesn't exist. For all we know this is a deliberate backdoor left open for the US government and has been exploited since forever in places that would never report it.
Reply 47 of 151, by spiroyster
True... they'll be around at some point though no doubt... exploit it... and they will build it... and they will cum. o.0, Crafty little buggers some of these malware authors can be, and naive little buggers these script kiddies can be (trigger pullers)... but it also wouldn't surprise me if there are 'unofficial' patches available at some point if it really is a problem that warrants the effort.
And yes It should be stressed that no one currently 'suffer's Meltdown and Spectre, they have the potential to 'suffer' it. It all needs to be reviewed on a CPU by CPU basis. Theorectically this exploit can jump into host OS, but it begs the question, would this still be the case for a 'patched' guest OS running on an 'un-patched' host OS? I have no idea how virtualised kernels operate wrt the host kernel space?
I think that's a bit too tin-foil-hat-tey, the more I look into it, it certain does look like simply a conceptual design oversight. There are posters in this thread obviously far more qualified to say either way than me though. Just mho.
Reply 48 of 151, by Malvineous
Let's not forget that this isn't some remote attack that can be run as soon as the machine is online, the code has to actually run locally on the CPU before it stands a chance of reading protected memory. Everyone is worried about web browsers and the vulnerabilities being exploitable through JavaScript, but only recent JS interpreters support what is required for this, and who runs a modern web browser on their retro PC anyway? Just use an old browser, turn off JavaScript, or use a patched web browser - Firefox reduced the precision of their timers recently to make the attack impractical.
It hardly makes the CPUs "unsafe". In fact if you go back in time looking at CPUs, pretty quickly you reach a point where they are too slow to run a web browser with accurate enough timing to execute the attacks anyway.
Really, this is no different to any other malicious code, be it a virus, trojan, etc. If a virus exploits a bug and gets into kernel mode then it can read everything as well, and a lot faster than Meltdown can. Most people try not to run viruses on their CPUs, and Meltdown/Spectre code is no different.
The real issue is people who need to run untrusted code as part of their business - namely cloud providers like AWS. They are the ones who really need to fix the problem or their core business model goes out the window. For everyone else, it's nowhere near as severe.
Reply 49 of 151, by spiroyster
Looks like Meltdown and Spectre already run on old hardware 😵
Reply 50 of 151, by dr_st
Then everything about you and everyone else already leaked, and you're just trying to close the stable door after the horse has bolted.
Yes, that's basically true. Something like RWEverything (which is scriptable) can dump all your physical memory using proper, documented Windows interfaces without using any bizarre exploits. The difference is, as far as I know, that on a properly secured system, RWEverything will have to request administrator privileges to work, while these side-channel attacks can leak RAM without any privilege elevations and without being detected. I think this is why everyone treats them as super-serious.
Reply 51 of 151, by bjwil1991
Except for the 8088/8086, 286, 386, and 486 machines. Pentium (as well as the OverDrive and Pro) and higher are affected by these bugs. AMD processors, not so much (zero chance according to the AMD team).
Reply 52 of 151, by appiah4
And that excuses liability? What difference does that make? Just because one source already monitored it all its now aok for everyone else? What exactly are you trying to say here?
Reply 53 of 151, by dr_st
That you are spreading FUD.
Reply 54 of 151, by appiah4
Oh. Youre a funny vuy.
Reply 55 of 151, by spiroyster
Did you clicky the linkyies? ... or was my joke that bad 😢
[EDIT:] 🤣... it turns out M$ might be doing more damage to AMD than Spectre ever could.
linky: https://www.theregister.co.uk/2018/01/08/micr … md_powered_pcs/
Reply 56 of 151, by dr_st
I'm not going to click any links on the web. My computer has not been patched yet! 😵
Reply 57 of 151, by bjwil1991
spiroyster wrote:
Did you clicky the linkyies? ... or was my joke that bad :depressed: […]
I got the joke. Didn't realize that those were games back then. Laughter is the best medicine.
Reply 59 of 151, by Scali
Super_Relay wrote:
goes back to the pentium 75mhz
Yes, but that does not imply that they included new microcode for these processors.
If you take the previous release, they also have that huge list of CPUs:
https://downloadcenter.intel.com/download/269 … ocode-Data-File
So it seems that this is just a 'bulk' file that contains the latest microcode for all CPUs from Pentium and up.
Could be that the Pentium microcode included there hasn't been updated in over 20 years.
The included release notes say:
IVT C0 (06-3e-04:ed) 428->42a SKL-U/Y D0 (06-4e-03:c0) ba->c2 BDW-U/Y E/F (06-3d-04:c0) 25->28 HSW-ULT Cx/Dx (06-45-01:72) 20-> […]
HSW-ULT Cx/Dx (06-45-01:72) 20->21
Crystalwell Cx (06-46-01:32) 17->18
BDW-H E/G (06-47-01:22) 17->1b
HSX-EX E0 (06-3f-04:80) 0f->10
SKL-H/S R0 (06-5e-03:36) ba->c2
HSW Cx/Dx (06-3c-03:32) 22->23
HSX C0 (06-3f-02:6f) 3a->3b
BDX-DE V0/V1 (06-56-02:10) 0f->14
BDX-DE V2 (06-56-03:10) 700000d->7000011
KBL-U/Y H0 (06-8e-09:c0) 62->80
KBL Y0 / CFL D0 (06-8e-0a:c0) 70->80
KBL-H/S B0 (06-9e-09:2a) 5e->80
CFL U0 (06-9e-0a:22) 70->80
CFL B0 (06-9e-0b:02) 72->80
SKX H0 (06-55-04:b7) 2000035->200003c
GLK B0 (06-7a-01:01) 1e->22
You can deduce the codenames from the 3-letter codes. They all seem to be modern CPUs (Ivy Bridge, SkyLake, BroadWell, Haswell etc).
So nothing in there that proves that Core2 and earlier are affected/patched.
