Reply 1500 of 3179, by Auzner
wrote:a mounting hole on the PCB is missing
Time for a new rev!
wrote:the standoffs/screw posts of the joystick port would keep the bracket attached
wrote:Why not 3D Print them ?
That could be done to create a plastic jig. Take a blank IO plate, put it in the jig, use a punch tool, drill out holes. The jig holes would be smaller than the actual jacks so just to line up the punch tool. The DB-15 would be 2 bracket holes, 4 corner holes, and a center most hole.
