Reply 360 of 894, by CapnCrunch53
Added myself to the list too; this is so cool!
PCs, Macs, old and new... too much stuff.
Reply 362 of 894, by Arvid
Added myself to the list, this is a great project and I´m really looking forward to this batch being made 😀
Reply 363 of 894, by timitt
Got to love these projects. I don't have any intelligent mpu-401 cards, so I added myself to list.
I did not really understand what that count in google docs was (+24-3), but let's hope there's still room for that bigger batch.
Reply 365 of 894, by Cadderlik
Payment by PayPal?
Reply 366 of 894, by Thrax
I am interested in 1 card! 😀
I hope just in time i check in 😀
Thanks 😀
Reply 367 of 894, by keropi
Here it is (my test card so no fancy rom label), the first small batch of the MPUs with their fixes -> these fixes offer soundblaster16-level wavetable header compatibility and some minor stability improvements just in case 😀
Needless to say the fixes will not be needed on the next batch since they will be incorporated to the pcb design.
- there are 3 pins removed from the wavetable header (one is not used the other 2 are the audio-inputs to the daughterboard - the mpu did not use these anyway) and some small patchwork on support logic:
- at the backside 3 passives are added: one resistor and 2 small capacitors
That's it! Wavetable header issues are resolved, external midi connection through DB9 is the same as before - no changes or additions done to that so expect the same level of compatibility like the original Music Quest PC-MIDI MPU 😀
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 368 of 894, by voodoo5_6k
Congratulations!! Outstanding work, my friend 😀
END OF LINE.
Reply 369 of 894, by fitzpatr
Well done, Keropi! I've been very happy with my original model from you, and this one adds the perfect set of features.
I'm looking forward to getting one!
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 370 of 894, by keropi
thanks 😊
btw marmes deserves more credit for this than me 😎
Reply 371 of 894, by hard1k
How much do I hope that one day someone (dreamblaster? 😁) produces a wavetable daughterboard with the same nice blue finish! It would make such a nice couple with this card and the SQ2500!
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 372 of 894, by dreamblaster
wow, nice work !!
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 373 of 894, by hard1k
Just my 2 cents for the next batch:
1. Maybe an MPC header for the Stereo Out is worth installing - this way we could feed the stereo out into the mixing soundcard internally.
2. Maybe an input stereo jack wired to those 3 missing pins on the waveblaster header could be of some use too - many of us have NEC XR375, and this input jack would allow us to feed the stereo signal in an opposite direction: from the sound card into the daughterboard, going through its effect processor, and then coming out on the Stereo Out jack. As of now such thing is implemented in the Audiotrix 3D-XG card (bundled with the Yamaha DB60XG), but good luck finding one 😁
AWE64 Legacy
Reply 375 of 894, by soyunnazgul
Great job. Waiting for my turn in the list.
Reply 376 of 894, by keropi
I can see this being useful , ever since I moved to an external mixer I don't really think about soundcard connections because I was fed up with the different sound levels between midi and sfx 😵
I once thought about that but what exactly would be the use? Because the MPU is no Audiotrix 3D-XG with dedicated drivers/design for that, I mean imagine there is a connector to feed your SB on the XR385, how exactly will you control the DSP to apply fx? Send a sysex? -> this will also go to any other synth connected and even if you can avoid that then imagine you run DOOM: everything is reset and the XR385 starts playing whatever midi stream DOOM sends over.
I just can't see how this can be used 😕 😕 😕
Reply 377 of 894, by Cadderlik
When are You going to send cards? I am just asking because I am first on the list 😀
No hurry, just asking.
Reply 378 of 894, by hard1k
Yeah, actually I agree. Should have thought about it a little bit longer 😀
AWE64 Legacy
Reply 379 of 894, by keropi
@Cadderlik
I have a couple ready now, tomorrow I will have ~10 cards packed and ready to go Thursday morning
@hard1k
yeah it suxx ... more features = better but you can't always win...
