First post, by old_MySpace
-SNIPPED-
Reply 1 of 8, by cyclone3d
It is AC'97.. therefore no DOS support.
If you really want to delve into AC'97 DOS support, see these. You will be able to play CDs and Wave files, but nothing for games:
http://www.bttr-software.de/forum/board_entry … =DESC&be_page=0
http://www.georgpotthast.de/dossound/
You could also use VDMsound which should work pretty ok-ish for running DOS games from within Windows.
https://en.wikipedia.org/wiki/VDMSound
You can use DOSBOX to run DOS games from within Windows and that will give you sound.
Does the PCI sound blaster card work in a different computer? If so, have you tried all the different PCI slots in the computer you want to use it in? Sounds like either a resource conflict or a dead card to me.
The PCI sound blaster cards are not going to give you a optimal/very good emulation for OPL3 music in games, but sound and MIDI music should work ok.. maybe.. depends on the chipset of your motherboard.
Good PCI sound cards that support DOS are:
Anything with a Yamaha YMF7x4 chipset (watch out for relabeled CMI chipsets)
Some ESS chipsets - Solo-1 being the most popular
Some Crystal chipsets
Aureal Vortex/Vortex2
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 8, by old_MySpace
-SNIPPED-
Reply 3 of 8, by cyclone3d
Don't worry about the legacy audio setting in the BIOS. For that sound chipset I highly doubt that setting would be in any of the BIOS versions as it doesn't support DOS at all.
YMF7x4 Guide
Reply 4 of 8, by Kamerat
cyclone3d wrote:
Good PCI sound cards that support DOS are: Anything with a Yamaha YMF7x4 chipset (watch out for relabeled CMI chipsets) Some ESS […]
I don't have much success with ESS Solo-1 and Crystal 4630 on SiS chipsets. YMF7x4 might work if your southbridge is a 962 or older, same goes for Avance Logic ALS4000.
MySpace wrote:
Thank you very much for the explanation!
I will try tomorrow the sound blaster on another computer. The fact is, in the same PCI slot that the sound blaster was in there is now a modem PCI card which is working fine.
If I manage to get that Soundblaster to work, do I need to fiddle with legacy audio thing in the bios or not? Since it's not there.
SiS 7012 don't support legacy audio as the SiS7018 did (found in 635 and 735 chipsets).
For your Live! you can try cleaning the PCI connector of the card, also try it in different PCI slots. You can also try to manually configure the IRQ of the PCI slot you're using, that's usually possible on boards with SiS chipsets.
YouTube channel
Reply 5 of 8, by Weebob
As others have stated try the other slots.
I had a load of audio problems with the card in the lowest slot on the board, it must share resources with something else. Moved one slot up and it was fine.
Reply 6 of 8, by yawetaG
And try disabling the onboard audio in the BIOS.
Reply 7 of 8, by old_MySpace
OK, I managed to get from the local store a Sound Blaster CT5808 PCI, now the audio works in Windows 98 and DOS games that I run in Windows.
Now, how I can make it work in pure dos mode too?
The game that I'm testing it is Wolfenstein 3D.
Reply 8 of 8, by gdjacobs
If SBEINIT runs during Windows startup, you should be able to exit to DOS and use your SB PCI card.
