First post, by Guest
When will it come out? I want the 3.1 windows emu.
Reply 1 of 3, by HunterZ
I've heard that you can boot Windows 3.1 in the CVS builds of DOSBox. Check the development forum for more info.
Reply 2 of 3, by avatar_58
You can. I've got it running under the AEP build before with full 256 colour support. Check the guide section for help. The only problems I had is windows freezing during the install...it happens every so often. Make sure you have dynamic CPU disabled when setting it up or changing settings.
