First post, by jheronimus
- Oldbie
Hi, all
I recently got myself a Gravis Ultrasound PnP (non-Pro). I'm using a Pentium 60 Intel Batman's Revenge board to test it. It's running DOS 6.22 and Windows 3.11. I've removed everything but a Tseng ET6000 VGA card and a 3COM network card (need it to download drivers). Here's what I've tried:
1) I've tried Ultrasound 4.11 installation disks from here. Install.exe detected the card, but I couldn't configure the card through Setup.exe — it would fail at testing any port/IRQ/DMA I've tried.
2) I've tried Ultrasound PnP disks from Vogons' Drivers.
I've ran through install.exe and automatic setup.exe but the system would hang at boot when the Gravis initialization started.
I've tried manual. Here are the settings:
Baseport — 240
Ultrasound IRQ — 12
SB IRQ — 7
Play DMA — 7
Record DMA — 5
CD-ROM — disabled
MPU — 330
MPU401 IRQ — 9
Joystick port — disabled.
All ports have tested fine. However, only 32K of RAM is detected (I've put two SIMM sticks in). Now I can boot and initialize GUS just fine. However, I can't get the sound anywhere, including Tyrian's setup tool and Ultimate Doom.
What am I doing wrong?
