Are Voodoo graphics card THAT good ?
Reply 60 of 183, by Warlord
Another nice thing about voodoo 3 is that the best voodoo 3 you can get was the most commonly available card. The compaq v3500 OEM board that is 183mhz. It is the same GPU as the 3500 TV card but without the TV tuner. There is no use for the TV tuner in 2018 so yea. These cards also outperform v2 SLI so its basically the best all around 3dfx card imo.
Reply 61 of 183, by infiniteclouds
Compaq V3500s may have been so at one time... but you will find more Voodoo 5s for sale than Compaq V3s these days. According to some benchmarkers around here, though, it seems like the Voodoo 2000s usually have the same overclocking abilities as the 3500s while the 3000s tend to be more limited.
Reply 62 of 183, by Radical Vision
That is if someone want to have all possible 3Dfx models and versions of them, is way easier just to stick, with whatever you can find, as exotic things are really hard to get, but some times miracles happen...
No matter how will V2 SLI perform, they are still x2 cards and total of 6 3Dfx chips to one card and one Avenger chip, so the Voodoo 3 will win every time..
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 63 of 183, by dr.zeissler
I combined my V3 with a V1 and use a loopcable without any negative effects on the image-quality.
Reply 64 of 183, by Errius
Are there games that work with V1 but not V2 and V3?
Is this too much voodoo?
Reply 65 of 183, by dr.zeissler
some old games work best with v1 especially dosglide.
Reply 66 of 183, by infiniteclouds
From what I've read here a Voodoo 2 can be coerced through patches or other means to run many Voodoo 1 games but I would say that if you already have a Voodoo 3 it's probably better to just get a Voodoo 1 to shore up compatibility. I'm not sure that there are any 'native' V2 games that can't be made to work properly on a Voodoo 3.
Reply 67 of 183, by dr.zeissler
Reply 68 of 183, by leileilol
Off the top of my head, just that crappy 3dfx Blood port, and probably the 3dfx Mechwarrior 2.
Reply 69 of 183, by dr.zeissler
I'm not sure that there are any 'native' V2 games that can't be made to work properly on a Voodoo 3..
I know none.
Reply 70 of 183, by leileilol
Well I do know of one of those - Montezuma's Return!.
Reply 71 of 183, by infiniteclouds
Looks like a cool game. So this is made for a Voodoo 2 (not V1 and therefore not needing tweaks) that does not work on a Voodoo 3?
Reply 72 of 183, by Radical Vision
Voodoo Rush is one of the better 3Dfx cards, first 2D/3D in one, also the size of the card is like Voodoo 5500 and i like that...
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 73 of 183, by spiroyster
Reply 74 of 183, by Srandista
...if not the best! 🤣
Reply 75 of 183, by blurks
You better listen to this guy. He knows his stuff...
Reply 76 of 183, by firage
The hate is a little exaggerated, as the 8MB Rush didn't compare that much worse than say the Banshee did in its time. Worked great for a lot of Glide/D3D stuff.
My big-red-switch 486
Reply 77 of 183, by spiroyster
True... It's in my Top5... along with S3 Virge, Verité, NV1 and some 2MB 'ViewTop' display adaptor (VESA compatible) I had... all loosing out to the 2MB 'ViewTop' display adaptor (VESA compatible)... in this league, I don't think there is a better 3dfx?
Reply 78 of 183, by firage
It lost a bit compared to the Voodoo Graphics that was leading the market, in performance and compatibility, but you could've done worse with a 3DLabs Permedia 2 or something.
Reply 79 of 183, by spiroyster
Top7 then... along with Premedia2 and 'something'. I will never know 😀 (or learn it seems 😵 ).
