First post, by Errius
Hi, Carrier Command fails to run with a "key disk not found" error. I've tried both running the original disk in A:, and also mounting an image of the disk as a virtual drive. The disk has no errors. Is this game runnable on DOSBox?
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
When does that error happen? Or rather do you need to install the game and then when you run it, this error happens? (maybe you didn't keep the floppy(img) mounted)
Maybe you need to set the label correctly for the floppy.
Does it work in real dos?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 6, by Errius
There is no installer. The game is run from the floppy. Label of the floppy is "CARRIER PC". I don't have a real DOS machine to hand now, but will test it there tomorrow.
ETA: Game runs in pure DOS with no problems.
Reply 3 of 6, by Dominus
DOSBox Moderator
There is a switch to the mount command to set a label.
It might be that the game uses some copy protection that will require you to boot dos in Dosbox
Reply 4 of 6, by Errius
Using a bootable MS-DOS 6.22 HDD image, I see that the floppy image has the correct label, but running the game gives me the same key disk error.
I understand there is no way of accessing a physical floppy in this environment?
Reply 5 of 6, by NewRisingSun
DOSBox mounts only the files on your physical disk. .IMA-format image files only contain standard sector data but no low-level structures. Keydisk checking routines depend on the latter. Keydisk-protected games are invariably incompatible with (vanilla) DOSBox in their unaltered (uncracked) state.
Reply 6 of 6, by coolhaken
If you can make a floppy image, then I'll suggest making a .TD0 diskimage using Teledisk. Maybe it works with PCE emulator (http://www.hampa.ch/pce/pce-ibmpc.html).
