First post, by Tmp2k
I've got a system that boots all versions of Windows. It has an AGP TNT2 and a PCIe 9600 GSO. BIOS is set to boot from AGP. So DOS, Win3.1, Win9x etc all work fine. Win2K and WinXP boot from AGP but as soon as the bootloader has finished and Windows takes over it switches to PCIe. In 2K and XP I just installed the 9600 rivers and disabled the TNT2 in device manager and it worked.
Win7 will not let me choose the 9600 as the display adaptor unless I set BIOS to boot from PCIe. This is really annoying as it all works perfectly in 2K and XP!!!
Any ideas how I can force Win7 to use the 9600 on PCIe instead of the AGP card? Even if I disable the TNT2 in hardware manager, it still boots up using generic VGA, it shows the 9600 but you can't even add it as a second display.
