First post, by Kalistan
My screen now goes only to widescreen and the menu bar is sometimes there, leaving black bars on the bottom and top. I have tried fullscreen, fullfixed and aspect correction in all the ways possible but it doesn't seem to have an effect. I have tried uninstalling and reinstalling but it does the same thing. It's like it's broken or in my registry or something. If anyone can help i would appreciate it
Reply 1 of 5, by avatar_58
What is your resolution set to? Try 640x480 and then play with the apsect ratio, full fixed, scaling and etc to see it helps.
Reply 2 of 5, by Kalistan
I tried all that and to no avail. If i set it one 320x240, i only see a little magnification of the screen
Reply 3 of 5, by eL_PuSHeR
Is hwscale set to anything higher than 1.0?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 5, by Kalistan
Unfortunately, no, the hwscale is regular 1.00
I tried installing guizikavs and moe's version with still no results.
it's unusual, maybe my opengl or sdl is in a directory and linked to it now. I don't know
Reply 5 of 5, by eL_PuSHeR
I think you mean Gulikoza's build....
Ykhwong is also doing some nice DOSBox builds (CVS versions).
Other than that, try switching among the various output=xxxx rendering types.
Intel i7 5960X
8 GB DDR4 (2100)
