486dx2 working as a dx4?
First post, by Ltsyrek
Recently I bought Chicony CH-471A(Ver.3) motherboard with a 486dx2 - 66 plugged into a socket. Despite setting jumpers to configure it as a 486dx2-66, it is being detected as dx4-100 mhz, and it is reported as it in benchmark software. Its speed is much closer to 5x86-133 than to 486dx2-50, according to Speedsys. Do I have buggy CPU? Or maybe does BIOS or benchmarks are misidentifying it and it is working in internal frequency despite the wrong detection? If not, is it safe to run this CPU with such speed?
Reply 1 of 18, by alvaro84
What voltage does the CPU running at? Most DX2 parts were 5V ones but if it really runs at 100MHz it means that it has the 3x multiplier and is a DX4 indeed (it has 2x multiplier too - usually jumper selectable - so it can work as a DX2 too). What do its markings say?
There were 3V DX2s and I can easily imagine that these were actual DX4 parts 'binned' to DX2s.
If it's the case you should run the CPU at 3.3V instead of 5V but it must be printed on the CPU itself too. It should have an "&E3V1X" marking or something similar if it's an Intel part, simply "3 VOLT" if it's AMD, or something like "3.3 V" in case of a Cyrix.
Oh, and if it runs stable and at 3.3-3.45V it's perfectly safe to use at 100MHz (internal). At 5V it'll run much hotter than intended but may survive many years with sufficient cooling. I wouldn't bet my life on it though. Better safe than sorry.
There must be a FET close to the CPU that generates 3.3V from the 5V rail. Google showed that not every version of the board has it. And you must set it via the proper jumper too.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 2 of 18, by noshutdown
is your cpu from intel, amd or cyrix?
some dx2 cpus(most likely 3.3v ones from amd) may work at 3x clock if you set the clkmul pin to 3x.
also note that wt and wb 486s use different pin for clkmul. wt cpus use B13 pin for clkmul, which happens to be the pin that toggles cache wb/wt mode for wb cpus.
Reply 3 of 18, by kixs
I had one like that too. It was some AMD DX2-66. But only the jumper for WriteBack cache turned the multiplier to 3X. I also tested with other DX2 cpus, but 3X only worked with that one.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 4 of 18, by Ltsyrek
It is Intel A80486DX2-66. It has that "&E3V1X" marking written on it.
I also checked voltage settings and apparently it is running at 3.15V.
I already tested it for several hours and it seems perfectly stable and cool with heatsink and a fan.
When I was trying to change multiplier from 3x to 2x via jumpers it was working at 66mhz, but also the system bus was underclocked to 22mhz. Weird...
Well, if you are saying that it should be okay, then I'll leave it as it is.
Reply 5 of 18, by noshutdown
wow, never seen 3.3v 486dx2 from intel, i thought that intel only made 5v 486dx2.
Reply 6 of 18, by derSammler
Picture, please.
Reply 7 of 18, by Ltsyrek
CPU:
BIOS detects it as:
Reply 8 of 18, by derSammler
It apparently does CPU auto-detection and fails on that, leaving the CPU overclocked. Check the BIOS if you can disable CPU auto-detection (unless you want to keep it that way).
Reply 9 of 18, by Ltsyrek
Yeah, I' m keeping it that way. There is no such option in BIOS, the only way to set it is via jumpers (already set to 486DX2).
Reply 10 of 18, by derSammler
It may change if you set the L2 cache mode from wt to wb (or vice-versa).
Reply 11 of 18, by The Serpent Rider
I believe this AMD DX2-66 could be such example too. 16kb cache, write-back.
Reply 12 of 18, by Ltsyrek
There are no L2 cache config jumpers on the motherboard. Changing cache mode does not change the CPU detected.
Reply 13 of 18, by derSammler
Nice, i have one of those. 😁
Reply 14 of 18, by The Serpent Rider
So I've tested Am486DX2-66V16BGC (which I've mentioned before) on the Luckystar LS486E board and looks like it's really relabeled DX4. In fact that's Am5x86 133ADZ (same thermal package) with locked 4x multiplier - jumper settings for Am5x86 133mhz reset it to DX2 66mhz.
Reply 16 of 18, by The Serpent Rider
I can post photos tomorrow, but why though? That's just common Luckystar rev. C2 board.
Reply 17 of 18, by W.x.
The Serpent Rider wrote on 2018-03-14, 14:13:
This is interesting... so this CPU can run in 2x and 3x mode, but they've disabled 4x mode? In other words, normal AM5x86 133ADZ sets 2x as 4x, but on AM486DX2-6616BGC they've modified it in chip, so it runs as 2x?
I'm looking way to set regular AM5x86 133ADZ to 2x , can it be done somehow? Or is this behaviour hard-coded into chip?
Reply 18 of 18, by The Serpent Rider
No, I think it's not possible. 5x86s were highjacking DX4 multiplier changer, which is working like on/off switch. So it had to be done inside.
