Illegal Command: IPXNET.
First post, by lhunath
My issue is as follows:
I run Dosbox on Linux (Gentoo). I attempted to accomplish running games in IPX networking mode, with no success. I tried versions 58, 63, and now cvs. And yes, I do have ipx=true in the config..
Let me clearify myself:
I run dosbox, mount my c, and type ipxnet help, as documented. Appearantly, this is not a built-in command, because dosbox returns "Illegal Command". 'ipx' returns "true". HELP mentions no IPXNET commands.
Anybody who can enlighten the problem and assist in resolving it?
Thanks,
Lhunath
Ps./ Does the fact that Linux doesn't allow binding to ports < 1024 cause difficulities connecting between dosbox' on windows and linux hosts?
Reply 2 of 4, by lhunath
Goodness gracious. Ok, thanks. (Built-in huh? 😉)
How about my second question?
Reply 3 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Maybe it would be wise to change the default port to something > 1023 (-> 2644?, it's also about IPX tunneling) so linux people don't run into this.
You can run "ipxnet startserver <number>" and
"ipxnet connect <number>" on the other computer. Number must be the same. Should be platform independent.
Reply 4 of 4, by canadacow
I would advice against changing the default port as this would violate the RFC spec for IPX over IP.
http://www.faqs.org/rfcs/rfc1234
