First post, by fitzpatr
Good day, everyone. I've been active here for over a year now, and I help people troubleshoot where and when I can. I've noticed that we have no set standard for people posing questions, and no catch all troubleshooting or FAQ guide. I'd like to help out by providing, at least, a basic list of required information from anyone posing these sorts of questions. Hopefully, this will cut down the time that it takes for a problem to get resolved, and also make it easier on those more knowledgeable by cutting down on having to ask for the same information all of the time. It should also prevent us from having to Google the motherboard, etc. each time to determine things like chipset, etc.
[b][u]SYSTEM SPECIFICATIONS[/u][/b]
[b]Operating System(s)[/b]:
[b][u]Motherboard[/u][/b]
[b]Motherboard Model[/b]:
[b]Motherboard Chipset[/b]:
[b]Motherboard Revision[/b]:
[b][u]Processor(s)[/u][/b]
[b]CPU[/b]:
[b]CPU Frequency[/b]: 450MHz @550MHz (100MHz x 5.5)
[b]CPU Socket[/b]:
[b]CPU Cooler[/b]
[b][u]RAM[/u][/b]
[b]RAM Amount (MB) and configuration[/b]:
[b]RAM Type[/b]:
[b]RAM Speed(MHz)[/b]:
[b]RAM Timings[/b]:
[b][u]Hard Drive(s)[/u][/b]
[b]Hard Drive(s)[/b]:
[b]Hard Drive Connection Method[/b]:
[b][u]Removable Media[/u][/b]
[b]Floppy Drive(s)[/b]:
[b]Optical Drive[/b]:
[b]Optical Drive Connection Method[/b]:
[b]Optical Drive Analogue Audio Out connected[/b]:
[b][u]Display Adapter(s)[/u][/b]
[b]Graphics Card(s)[/b]:
[b]Graphics Driver and Version[/b]:
[b][u]Audio Device(s)[/u][/b]
[b]Sound Card(s)[/b]:
[b]Sound Driver[/b]:
If ISA{
[b]Base Address[/b]:
[b]IRQ[/b]:
[b]DMA[/b]:
…Show last 16 lines
[b][u]Power Supply[/u][/b]
[b]Power Supply[/b]:
[b]-5V supplied[/b]:
[b][u]Miscellaneous[/u][/b]
[b]Other cards installed (LAN, USB, Modem, etc.)[/b]:
[b]If DOS problem[/b]{
paste:
AUTOEXEC.BAT
CONFIG.SYS
Here is an example:
SYSTEM SPECIFICATIONS […]
Operating System(s): Windows 98SE
Motherboard
Motherboard Model: Gigabyte GA-5AX
Motherboard Chipset: ALI Aladdin V
Motherboard Revision: 4.1
BIOS Version: F4
Processor(s)
CPU: AMD K6-III+/450APZ
CPU Frequency: 450MHz @550MHz (100MHz x 5.5)
CPU Socket: Super Socket 7
CPU COOLER: Startech Socket 7 Heatsink with Fractal Design Silent Series R2 50mm Fan
RAM
RAM Amount (MB) and configuration: 256MB (1x256MB)
RAM Type: PC133 SDRAM
RAM Speed(MHz): 100MHz
RAM Timings: CL2
Hard Disk Drive(s)
Hard Drive(s): Samsung Spinpoint 4.1GB
Hard Drive Connection Method: Primary IDE on Motherboard
Removable Media
Floppy Drive(s): 3.5" and 5.25"
Optical Drive(s): LG GSA-4163B DVD+/-RW
Optical Drive Connection Method: Secondary IDE on Motherboard
Optical Drive Analogue Audio Out connected: Yes, to Sound Blaster Pro 2
Display Adapter(s)
Graphics Card 1: Matrox G400 Max
Graphics Driver and Version: Matrox 6.83.017 (dated 08-July-2002)
Graphics Card 2/3: STB Black Magic (3dfx Voodoo2) 12MB x2 in SLI
Graphics Driver and Version: fastVoodoo 4.6
Audio Device(s)
Sound Card 1: Sound Blaster Pro 2 (CT1600)
Sound Driver: From Floppy
Base Address: 220h
IRQ: 7
DMA: 1
Sound Card 2: Roland MPU-401AT
Base Address: 330h
IRQ: 4
Sound Card 3: Sound Blaster Audigy 2ZS Platinum
Driver: Creative CD (VxD)
Power Supply
Power Supply: Seasonic M12II-520W Evo
-5V supplied: With Adapter
Miscellaneous
Other cards installed (LAN, USB, Modem, etc.):
Intel Pro/100 PCI Ethernet
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 1 of 4, by Warlord
It's helpful thanks, that make the positive change..
I think when someone asks a question though usually they don't know the answer. Circular reasoning leads me to think that if they were technical to provide all the info that you listed they could be technical enough to trouble shoot their own problem or figure it out themselves.
I really believe just a cut down version of Motherboard Model is enough in most cases, and we don't necessarily need to know about specifics. A lot of info we can deducted just by the motherboard model, we can figure out the chipset we can figure out what ram it takes, and generally what compatibility issues it has and expansions or upgrades that are possible.
The problem usually is that people don't even know what they are doing.
Reply 2 of 4, by fitzpatr
Warlord wrote:
It's helpful thanks, that make the positive change.. […]
Good feedback! Thank you. I agree that it may be a little more information than is always required. I do partially feel that it should provoke a bit of research on the part of the seeker of help, and that it would be beneficial for them.
Motherboard revision could be removed, although I can think of instances from 486 platforms up until Core 2 Duo where that is directly relevant to compatibility, component mismatches, etc. In some cases, it can even mean causing significant damage to the motherboard or a card. For that reason, I'd rather keep it in.
486 Build
Reply 3 of 4, by dionb
Agree with both of you I'm afraid.
Yes, the asked information is all too frequently relevant, but no, it's not likely your average user would know how to fill out the template. Here at Vogons the average technical level is quite a bit higher than most other internet forums. I'm a long-time moderator of the hardware pages at a large Dutch-language one famed for good technical knowledge and our users are no Vogons 😉 Problem is that templates by definition are aimed at the least knowledgable; those who already know a lot also know how to provide information needed for a good answer, it's the people who don't who need the template - and then the old rule comes into play: the more you ask, the less accurate the information gets. Someone struggling with the idea of naming the components in a PC (of any age) goes blank when you require something like motherboard revision (even if it's silkscreened in big, clear letters on the board, right under the board model...) or BIOS version (even if the board boots fine and the version is displayed clearly every time, both in the top and in the string at the bottom of the screen).
What for an experienced tinkerer is just two basic data points for someone less experienced turns into the effort of having to understand the question, then having to figure out the information might in general be found, followed by how it looks in their specific situation (not all boards have the info silkscreened so nicely..) and if you're lucky then double-checking to see if the found value makes sense. And then to repeat that effort maybe 20 times to fill out the template. Just getting the info on the motherboard would cost someone like that much more time and stress than you or me doing the whole template (as we know this shit by heart having consciously configured it all).
Call me a cynical old bugger, but I don't think there's a magic fix here:
- no template (current situation) means too many topics with too little info meaning those who want to help have to spend a lot of effort teasing out the relevant information.
- a minimal template has a decent chance of being at least partly correctly filled out, but more likely than not does not supply enough information to make cause and so solution, so you still need to spend time & effort getting the relevant stuff.
- an extensive template stands a good chance of getting all the relevant information in one go, but not a hope in hell that the template will actually be used, or if enforced will be completely and correctly filled out. Plus these things have a tendency to creep - today this list should suffice, but tomorrow someone notices that sound card revision, or posision on IDE/SCSI cable is relevant...
Much as I agree with the necessity of the things asked here to get a good picture of a system and what is going on in it, I'm afraid I'd have to side with Warlord and say that any template needs to be much shorter to stand a chance of being sensibly used. Just the device names would at least give us a ballpark to work with.
That said, there are two questions missing that is are least as important as any specs:
- Steps to reproduce. We should explicitly ask the topic starter to describe step by step everything he does between turning his computer on and seeing the problem he faces.
- Exact error message(s). If any errors occur, include - verbatim - the error message(s).
Reply 4 of 4, by Tetrium
Pics will often definitely help!
Personally I wouldn't want such a form to be mandatory, but I do like the idea behind it 😀
If some essential bit of info is not provided, I'll just ask. If someone doesn't understand then I'll try and explain what bit of info I need.
Often if someone asks a question without giving any basic information about the system the person is trying to troubleshoot, mentioning the basic info we need in order to be able to help him just once is often enough to give them a nudge in the right direction.
To me it's not just telling unknowledgeable people what they are missing, but to help them learn how to deal with these issues themselves. Part of this is that people actually want to understand how stuff works.
Many people here basically started from scratch. When I started I didn't even dare to open up my PC and 10 years later I'm not afraid to handle hardware components as I know exactly what I'm doing (or I would hope so 🤣).
In the end these older rigs need an approach that is basically universal to a certain degree. Some people asking questions here will get the retro bug and start delving into the matter which may result in they themselves becoming the knowledgeable source of information they once came here to seek and ask for help. This is part of what keeps Vogons going. It's about spitting out everything we know so that others can build on that and teach all of us, a common vat of knowledge. Other sites tend to get riddled with people who tend to be more vs each other instead of with each other and such sites are somewhat doomed to stay behind the competition, provided the competition is more about sharing information instead of monopolizing it.
My retro rigs (old topic)
Report spammers here!
