First post, by rob8086
Hi All,
First, let me say how awesome it is that this place exists. I had no idea you all were here, caring about this sort of thing when I thought I was alone in the universe.
Second... I wish I had known you were here two years ago! I built my own Win98 box specced as follows:
CPU: Tautalin PIII (SL6BY) @ 1.4GHz
MOBO: ASUS TUV4X (VIA Apollo Pro133T)
RAM: 1GB PC133 (2x 512MB)
GPU: Radeon 9800XT
Soundcard: SoundBlaster SB0350 (even though the mobo has onboard SB)
I've also got an 80GB 7200k IDE HDD, a DVD optical drive, a 500W PSU, yada yada.
I thought, when I built it, that I really had the research down pat. And I still think some of the choices I made are good ones (looking at you, Tautalin and VIA chipset). The biggest thing I'm concerned with right now is the GPU. I see on here, over and over again, that ATI cards should be avoided... yet I've had no problems with mine. The cards I see suggested on here seem like they wouldn't quite be powerful enough to max the games I want to max. I'm looking at basically anything that came out prior to the release of Windows XP as being fair game here. I use Return to Castle Wolfenstein as my kind of "bonus bench" since it came out a month after XP.
So I'm really curious here (and a little excited, honestly) to see what you lot might change about this build. I know there is a preference for the Intel i815E chipset, but that caps out at 512MB RAM. With Win98SE SP3, I've seen no reason not to push that to 1GB or higher (though really, I can't imagine any of these games using even the full gig I have already).
Anyway. Thanks for reading, looking forward to seeing your ideas!
Corruptor : ASUS TUV4X - Intel SL6BY @ 1.4GHz - 2x 256MB PC133 - ATI Radeon 8500 - Creative Sound Blaster Audigy2 ZS SB0350
Aggressor : ASUS TUSL2 - Intel SL6BY @ 1.4GHz - 2x 256MB PC133 - NVIDIA GeForce 4 Ti 4600 - Creative Sound Blaster Audigy2 ZS SB0350
Reply 1 of 6, by slivercr
Honestly, it looks pretty solid.
People recommend Geforce FX downwards because of support for fog table and 8-bit palettized textures, Radeons have no support for these (I think maybe fog tables through a registry hack? Not sure.). If you've had no problems, I'd just leave it as is. Well, I'd switch to an SSD, maybe overclock the Tualatin a bit too, but that's just me 😜
Welcome!
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 2 of 6, by rob8086
Thanks for the info! I think what I might end up doing is building a second machine. This one with an ASUS TUSL2 or an Intel D815EEA2/U just to try the Intel chipset. Kind of curious how much of a difference that 512MB less is going to make, if any.
I'm completely hung up on GPUs now, though. I think I'd love to get ahold of a Ti 4800 but they are completely impossible to find.
Reply 3 of 6, by KCompRoom2000
As far as the RAM limit on the i815E goes, it shouldn't be a problem on 9x systems, the need for more than 512MB of RAM starts with XP SP3+ as far as I'm concerned. I can't even think of a reason to need more than 256MB of RAM for a 9x system, so there should be little to no difference between 512MB and 1GB. 98SE has problems with more than ~512MB unless you use some patches from what I've heard.
Correct, you can re-enable fog table on ATI Radeon cards through the means of a registry hack as proven on this post here.
Reply 4 of 6, by Weebob
I had no end of problems on my 815eea2 on win98se with anything above 512mb ram. Random lockups mainly and general instability. Even after the various patches.
Reply 5 of 6, by nforce4max
I never liked the ram limitation of the 815 as the older BX handled 1GB just fine, 512 is generally accepted as the max limit of 98/me because having to spend $20 for a patch doesn't appeal very well to anyone.
Reply 6 of 6, by rob8086
I have had some stability issues with my current build, the one with 1GB in it. Thinking I might swap those 512's for 256's and see if anything changes. The next build is only going to be 2x 512MB for sure since it's the Intel chipset.
