Reply 1740 of 3184, by 640K!enough
Synoptic wrote:
All is good, except I did not understand I had to use the GF1 Megaem.CFG file.
I will record again.
That's not necessary; it already answered my questions.
Reply 1741 of 3184, by Synoptic
too late. check on previous page
Reply 1742 of 3184, by 640K!enough
Synoptic wrote:
When Loading MegaEM, it loaded the patch set in memory.
Mine still stubbornly refuses to load a RAM bank. Can you still post your configuration file?
Reply 1743 of 3184, by Synoptic
The attachment MEGAEM.CFG is no longer available
Reply 1744 of 3184, by keropi
allright, I finished my Argus:
I can also verify that the roms on UT are the real deal, checked both playback and md5 and it's all good. I will spend some time now using the card - I reported on soldering before so now it's time for usage I guess 😁
Reply 1745 of 3184, by Synoptic
My ROM should arrive today too.
Reply 1746 of 3184, by 640K!enough
Looking at keropi's picture of the completed board again, I am reminded of one thing, though it's probably not relevant to most here: the current pre-prototype ROM carrier board for the ARGUS definitely won't fit with that type of SIMM socket in place. So, if there's anyone planning on trying the first generation, plan accordingly. Even without the SIMM in place, the socket is too tall for the low-profile receptacles to be able to fit the module unobstructed. The only chance would be if it's possible to find tall receptacles or additional spacing headers. Personally, it is less expensive to just use an upright SIMM socket, so that will be my approach; the receptacles can be expensive enough without having to find additional or unusual parts.
Reply 1747 of 3184, by Synoptic
Got my ROM today too.
IWSBOS works
MEGAEM now loads innstruments from ROM instead of Patches.
Reply 1749 of 3184, by 640K!enough
Synoptic wrote:
IWSBOS works
When you decide to do some more testing, can you try the same MIDI files from a few days ago, configured for MPU-401 via the internal synthesizer? Recordings aren't necessary, just pay attention to missing notes and other things that sound off, compared to your SC-88 recordings.
Also, has anyone tried thicker SIMMs? Do all of them still clear the latches, or have any of them caused trouble?
Reply 1750 of 3184, by Synoptic
The attachment digiland - Left is GUS - Right is SC-88.mp3 is no longer available
Indeed, the GUS misses some of the snare drum at the begining.
Reply 1751 of 3184, by Synoptic
Any simms thicker than mine will not fit. My simm touches the latches.
Reply 1752 of 3184, by moturimi1
I assembled my ARGUS #11 today, unfortunately I do not get it to work.
So far I have not attached the SIMM RAM ADAPTER and GAMEPORT as I wanted to check the card first.
I have to mention that my solder skills are not good. I normally solder only condensators.
Soldering took me 4 hours, because I wanted to do it properly.
I was able to upload the EEPROM firmware.
Unfortunately the check sum of the IW78 Sound ROM is not correct. I dumped it more than once and each time I get a different check sum.
(I have the original IW78 ROM from utsource)
With IWINIT I do only get the message "Ultrasound card #1 initialized", but no further message. Keropi's initalisation shows more: https://imgur.com/PMXkzRR
For now I don't know where to start...
Reply 1753 of 3184, by shock__
Photo of the card would help to inspect the solder joints as a first measure.
Did you try iwinit with the -v9 parameter? Keropi's screenshot shows just as much, albeit a bit more due to an additional PNP Manager which is unrelated to the ARGUS.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 1754 of 3184, by moturimi1
Well the ROM has not been found.
https://1drv.ms/u/s!AuD8nQsQeS3hkGan3tudzo9k16LE
I have to take better pictures tomorrow.
Reply 1755 of 3184, by shock__
Bottom right solder joint on the ROM looks like it might be cold (Pin22).
When in doubt, resolder all joints on that chip again, same goes for the 74F373 latches.
[Z?]
Reply 1756 of 3184, by moturimi1
Thanks for the comment.
I used some flux to reflow both 74F373 and the IW ROM, but still no luck.
Here are more pictures:
https://1drv.ms/u/s!AuD8nQsQeS3hkGzySG2Ov_Lqge9w
https://1drv.ms/u/s!AuD8nQsQeS3hkGpJna1RENpBYhqQ
https://1drv.ms/u/s!AuD8nQsQeS3hkGmcTT_bH9BCll7q
https://1drv.ms/u/s!AuD8nQsQeS3hkGj3P2Bk2nEhCNpX
Any big mistake or missing jumper? I don't want to add the RAM header without knowing that the card is working properly.
Is it possible to test the soundcard under DOS. I mean digital sound. Maybe this does not work either.
Does IWINIT -v9 normally show a message if the IW ROM was detected?
Reply 1757 of 3184, by shock__
That's quite a catch-22 now. Without RAM you can't test the card further than you already did. Jumpers are correct. Initialization seems to be working apart from the ROM.
Solder joints on the ROM look alright - are you sure it's working? While most others seem to have had success with the chips from UTSource it's supposedly not the most reliable source so it could be that the ROM is simply dead. Another thing you could try would be sending me the 1MB ROM dump you get - maybe the data is semi-recognizeable.
I've recently ordered some to have them checked out by a friend to confirm they're factory programmed.
[Z?]
Reply 1758 of 3184, by moturimi1
I soldered in the RAM header. Unfortunately iwinit -v9 does not detect RAM.
But when I run setup.exe it detects 8 MB RAM. Strange.
https://1drv.ms/u/s!AuD8nQsQeS3hkSHuf_J7rZkR3SWW
https://1drv.ms/u/s!AuD8nQsQeS3hkSK7fR9m8QELAkpt
I am going to stop work on the ARGUS. Maybe I have to send the card to a vogons member to check it.
ROM content:
I have a EPROM Writer. I checked the ROM content before soldering and it was correct. I think something else is wrong.
(__shock, I contacted you on dosforum.de regarding the MD5SUM of the IW ROM)
Reply 1759 of 3184, by Phreeze
it seems that the content of the ROM i got burned from a friend is incorrect.....checksums don't match, eithe rfrom Start=0 or start=100000...
waiting for my IWs now..
ArGUS Parts list: http://bit.ly/2Ddf89V
