SCSI pains - AHA-2940U2W doesn't detect Cheetah
First post, by dionb
Two weeks back I was able to pick up a Seagate Cheetah ST39103LC 9.1GB 10k RPM U2W SCA SCSI drive for free. Yippee... but the only SCSI hardware I had was a Dawicontrol narrow SCSI card and an external Sun 5.25" enclosure with Plextor CDRW (and no cable...). Apart from the performance thing, I didn't have any narrow->wide adapters (or even any 50p flat cables for that matter). So if I was going to have to acquire something else anyway I might as well do it properly. So I located an Adapter AHA-2940U2W, and a nicely terminated 68p cable. This afternoon the AHA-2940U2W arrived, so I could get started. Only I got stuck pretty much immediately.
HW:
--- known good ---
Tekram P5MVP-A4 rev 1.01 motherboard
K6-3+ 450 (not currently overclocked, just plain 4.5x100@2.0V)
64MB PC100 SDR-SDRAM
Diamond Viper V770 TNT2-Ultra AGP
FSP-350-6PN (PF) PSU (ATX, 350W)
SCA-80 to HD-68 + Molex adapter cards (two different ones, simple passive things - behaviour is identical with both)
--- not known good yet ---
Adapter AHA-2940UW
50cm, 3 connector HD-68 SCSI cable with Amphenol terminator, rated for LVD and U320
Seagate Cheetah ST39103LC (set to SCSI ID 0)
SW:
Adapter SCSISelect V.2.20.0 GE
(yes, in German 😒 - my German is fine, but figuring out how technical terms were translated isn't my favourite activity in any language)
Issue:
The drive isn't being detected, regardless of what I do. What *does* happen differs depending on which connector on the AHA-2940U2W I connect the drive to:
  • If I connect the drive to the Ultra2-LVD/SE connector, the drive doesn't spin up. The LED on the drive does go on and stays on. The SCSI Disk Utilities drive scan completes normally, but no drives found.
  • If I connect the drive to the secondary (SE only) connector, the drive does spin up. The LED on the drive flashes a bit afterwards, the goes off. The SCSI Disk Utilities drive scan hangs on SCSI-ID 0 : LUN 0
Now, the problem is I have three unknowns (adapter, cable and disk) and don't have any other hardware to exchange to identify which is causing the issue.
Things I've tried:
  • Resetting SCSI BIOS to defaults.
  • Setting the HDD to a different ID, either through jumper on the drive itself or on the SCA-HD68 adapter.
  • Using the other connector on the SCSI cable.
  • Trying this set of tips from the Adaptec knowledge base from 1999 - basically altering SCSI host adapter settings to their most simple, compatible.
  • Swapping round the two SCA-HD68 adaptors.
  • Turning it all off, sitting down to a nice local craft beer and thinking nice positive thoughts. Then turning it all on again.
Nothing changes behaviour. I'm pretty sure something's dead, but if anyone has a better suggestion than "find some more SCSI cables, drives, or adapters and rule them out one by one" I'd be most grateful.
Reply 1 of 22, by FluffyBunnyFeet
try removing any jumpers that are on the hdd and set the id on the 68-pin-to-sca adapter. and since u have a terminating cable u don't have to terminate the drive. if i remember correctly, the sca drive won't have id jumpers on it since all that info is set by a sca back plane. another thing to try is force single-end mode on the drive.
Reply 2 of 22, by Warlord
The Adaptec AHA-2940UW are good cards but you need to flash them to the latest BIOS for them to be good. This should be a upgrade over a Motherboard that only has 33mhz IDE. or slower.
The host bus must have its own ID it can't be the same ID as the HDD.
What SCSI ID is your host bust controller? If it is 0 there is part of your problem. Set the host bus to 0 set the HDD to 1 or something else.
Have you pressed CTRL + A and went into the SCSI HB BIOS and played with the spin up settings? There should be 2 settings Spin up on power up or Delayed spin on detection. I think you should set it to power the drive up on power on.
Have you inspected all of the Pins on your scsi cable are not bent?
Reply 3 of 22, by luckybob
Ok, you have the scsi card, 68 pin cable, and 68 to 80-pin sca adapter, correct?
I don't hear you are using a terminator. you have 3 options
Buy one of these: https://www.ebay.com/itm/292293586108
Get a new cable with a terminator built in. (this is what I do, they have the above permanently attached.)
Get a new sca adapter like this: https://www.ebay.com/itm/112694609341
option 3 is just a 50-pin example, but notice the 3 small black things in the middle of the board. This board will terminate properly. I personally choose option #2 whenever possible. #1 is plan b. #3 is plan A if I'm doing something with 50-pin.
Reply 4 of 22, by luckybob
Also, set the hard drive to ID 1. Sometimes scsi controllers are on 0. This is changeable in the bios of the card. Leave it at the default value, and don't put anything else on that number.
Reply 5 of 22, by dionb
It has both - own jumpers and jumpers on the adapter. Both set to 0 (i.e. no jumpers anywhere), but also tried different values. No difference.
Tried that (had to improvise as the jumper for this was smaller than normal and not one I had), no difference.
Yep, particularly due to the low seek times of the 10k rpm drive - although in this case it was mainly intended as an upgrade from a 2GB CF card I managed to fry recently...
Should have mentioned that. Host controller was on ID3 (why?) when I got it, after reset to defaults it was back at 7. Either way no difference.
That was in the list of things to try from the Adapter knowledge base. Default was spin op power up and no delay. Tried all four combinations. Again, no difference. The only thing at controller side the drive is in any way responding to is whether I put it on the U2W LVD/SE connector or the regular SE one. No other settings are having any effect whatsoever.
They look regular & straight in all three connectors on the cable. Even though not advertised as such, the cable seems new&unused. Still no guarantees, but there's nothing in the way of damage or scuff marks I can find.
Anyway, the cable has three connectors and I've tried it with every combination that keeps the terminator on the right end, so if it was the cable or connector it would have to be faulty in at least two places. Not impossible, but unlikely IMHO.
luckybob wrote:
Ok, you have the scsi card, 68 pin cable, and 68 to 80-pin sca adapter, correct? […]
I'm already using option 2, a cable with a terminator. That does give me one other avenue to pursue - termination at the controller card is set to auto. There's a jumper to manually force that. I'll see if that makes a difference...
...and nope. Still either not spinning or being detected at all, or spinning up but hanging the device detection.
Oh well, was planning to raid a new and promising thrift shop this afternoon anyway. If they have anything SCSI I'll be getting it.
Reply 6 of 22, by feipoa
Might want to try a terminator intended for Ultra2-LVD and a flat ribbon cable. It seems like this has saved me in the past with a similar situation. You also might want to try the LW versions of the drives. I've run into one card that the didn't work well with the 80-pin to 68-pin adapter.
Reply 7 of 22, by Warlord
Just be a bad hard disk drive this would be my assumption.
Reply 8 of 22, by dionb
How is that different to the Ultra320-LVD terminator I have?
Will do so as soon as I come across one of those for free like this one 😜
It's sort of looking that way. Actively looking for another drive atm, but also for 50p flatcable and 50p-68p adapter. Apart from being able to use any drive with that, I can then also use my old Dawicontrol controller to rule out problems with the AHA-2940U2W. But of course just when you start actively looking for this stuff, there's not much locally, what there is is ridiculously expensive and elsewhere shipping costs more than the stuff is worth. Oh well, time to exercise some patience - SCSI is common enough, it'll turn up.
Reply 9 of 22, by feipoa
Yes, I believe the Ultra2-LVD terminator is different from the U180 or U320 types, but I'm not exactly sure how it is different.
Reply 10 of 22, by timb.us
If all the jumpers are off the Cheetah than it should be terminating itself. (The jumpers for terminator power and status should be on a small flat block on the bottom of the drive.) The AHA has built in terminators. So where exactly are you plugging in this external terminator? I’m not sure it’s actually needed in that case.
Any sufficiently advanced technology is indistinguishable from magic. (E.g., Cheez Whiz, RF, Hot Dogs)
Reply 11 of 22, by dionb
You sure that applies to the LC as well?
https://www.seagate.com/staticfiles/support/d … scsi/29410c.pdf
LC and LCV model drives are designed for installation in host systems that have a backplane with single connect […]
host systems that have a backplane with single connector
attachment (SCA) connections. Termination is normally pro-
vided on this backplane.
Host systems designed to use LC and LCV drives nor-
mally provide termination power from the host adapter or
other source. LC and LCV model drives cannot be config-
ured to provide termination power to the bus.
Sounds to me like it neither terminates nor provides termination power to the bus.
AHA 68p connector 0 ---flatcable--- 68p connector 1 --- flatcable--- 68p connector 2 ---short flatcable--- terminator (integrated into cable)
The SCA adapter with drive is plugged into either connector 1 or 2. I've also tried AHA on connector 1 and drive on connector 2 to see if that made any difference. It didn't.
Reply 12 of 22, by luckybob
The manual to that drive specifically states it does NOT terminate.
The fact the card hangs occasionally, tells me it is probably a cable problem. If I had your parts on my bench I could find the problem quick as I have the benefit of spare parts. Check the jumpers on the adapter. There should be one for startup. You want the drive to startup automatically. If you cant figure out which jumper this is, go into the card bios and look for an option somewhere that forces the scsi card to send out start signals.
Thats what i would try next.
Reply 13 of 22, by dionb
It's not 'occasionally', it's entirely reproducible. On the LVD-U2W connector on the 2940U2W it doesn't hang but isn't detected either, on the SE connector it hangs on detection. Given that the behaviour is consistent per port but changes with the cable, I'd say the cable is the least likely culprit.
If I had a second drive with SCA-80 or HD68 - or a 50p flatcable - I could do the same.
There are only two jumpers on the card, one for each bus to force termination. Everything else happens in BIOS. Automatic startup is an option and is enabled by default. Disabling doesn't change behaviour.
Am looking for some more hardware. Found someone nearby selling a box containing what looks like a SCSI drive, a SCSI adapter and a 50p flatcable. Unfortunately it also contains a Creative Sound Blaster 16 CT2290, which is pushing up the price drastically. Failing that I'll just have to be patient...
Reply 14 of 22, by luckybob
Well, keep it quiet, but I might be bidding on this: ***REDACTED***
I dont need the scsi stuff, so if I do get it, I can offer those parts to you pretty cheap. I'm mostly interested in the dual cpu board and one of the processors.
Reply 15 of 22, by luckybob
oh shit nvm, your in amsterdam. my bad.
Reply 16 of 22, by dionb
It's the old shipping story. There's enough old SCSI stuff out there, even enough for good prices. But even shipping inside the country would cost more than a 50p cable or a <10GB HDD is worth. Let alone sending that stuff across the Atlantic. So thanks, but not really practical, no.
If I get too fed up/impatient I'll just order something on eBay from Germany. Always enough items there, and shipping isn't too diabolical. But there should be something suitable to be had within a 30mins drive sooner or later.
Reply 17 of 22, by feipoa
Do any of those 80 pin SCA drives have terminator jumpers? I've never seen them with jumpers. I have some of those 80pin to 68pin adapter boards, but mine do not have jumpers for termination. The ones luckybob posted above had the options to terminate. Do those negate the need for a terminating cable?
Obviously, the advantage in the 80 pin drives are that they are significantly cheaper than the 68 pin drives.
Reply 18 of 22, by dionb
Nope, no terminator jumpers (or indeed resistors). Just the usual pins for ID, MTR, DLY & SYN - and a feed for some drive LEDs.
In this case the big advantage was that it was a freebie. Two friends of mine were dumping their old crap. Most of it wasn't old enough for me (So939-vintage) but this drive was, as were a few cards and - best of all - a serial to PS/2 adaptor so I can ditch my awful serial mouse and use a decent old Logitech trackball (PS/2 with serial support) instead. And then I went and fried my 2GB CF card, which meant that between a 10MB ST-412 I don't have a controller card for yet (should be in the post though...) and an 80GB SATA drive, this was the only storage option I had left for my So7 build. Also it's perfectly period, if unlikely that anyone would have used such a high-end disk in a K6-system back then.
Reply 19 of 22, by feipoa
At $28 USD each, I won't be buying any of these active terminator SCA-80 to 68-pin adapters to test. I bought the non-terminated types many years ago for about $2 each and they have worked fine for all my PCI SCSI cards.
