bjwil1991 wrote:Made a 100% functional A/V cable with noise reduction and clearer S-video (300 Ohm resistor soldered onto Pin 6) and composite signal for my C64 with "stereo" audio as well. New video: https://www.youtube.com/watch?v=Rjck5SRsKIk and I have to say, I'm proud of myself for getting the cable to function thanks to bloggers and advise from people on forums for both the DIY A/V cable and testing the SID chip. Going to use my USB Dazzle video capture card to capture footage from the C64 and posting it on YouTube. Next thing I'm going to make is going to be an IEC to Arduino Uno R3 with 3x 100 Ohm 1/8W resistors and make the 1541 emulation for games. If there's a way to make a cartridge version, much like the cartridge style floppy diskette drive for the Commodore Plus/4 and 16 (and 116) for faster load times, I'd be happy since IEC transfer rates are low (using a FastLoad cartridge + JiffyDOS in the near future would suffice).
Congrats... That is a good result. Kudos man'...
Waiting for my LumaFix64. Hopefully it will arrive within the next week. It will be needed, as I am in the process of setting up an LCD tv for both of my Amiga's and my C64. It will be used for DVD and/or Blueray playback as well. Plus it has VGA input. For the Amiga's I am going to use the two Scart input that are on the TV, and finally, I have Component for the best Playstation2 signal quality.
The setup is for both me and my son.
Regarding C64 Storage. Then why go through all that hazzle of using an arduino? On eBay you can buy various digital replacements with flash technology and or SD card. For cartdridge, you can get an easyflash. Floppy can be replaced with an SD2IEC and the Datasette can be replaced with an MP32C64 in combination with an smartphone.
EDIT: (links)
https://www.ebay.com/itm/MP32C64-COMMODORE-Da … UYAAOSwH2daf0p8
https://www.ebay.com/itm/Commodore-64-VIC20-1 … 08AAOSwURxanpP9
https://www.ebay.com/itm/EasyFlash-X-C64-Prog … hQAAOSw9qJaZjKd
Finally... There is a modern fastloader, that are build to be compatible with SD2IEC.
https://www.ebay.com/itm/Epyx-Fastload-RELOAD … VMAAOSwBt5ZGiS0
