Tandy 3 Voice Sound - SN76489 ISA Soundcard Project
Reply 20 of 484, by Solarstorm
matze79 wrote:
Current Progress:
Now i'm Searching a way to reset attiny on System Reset.
I think you could use B2 on the ISA bus.
http://pinouts.ru/Slots/ISA_pinout.shtml
RESET
This signal goes low when the machine is powered up. Driving it low will force a system reset. This signal goes high to reset the system during powerup, low line-voltage or hardware reset. ??????????????
My YouTube Channel
Reply 21 of 484, by matze79
Seems i only need a Inverter to Reset Pin of AVR 😀
just have very limited time.. i wish i could invest all time i have into my projects.. 😳
Reply 22 of 484, by Solarstorm
As far as i understand you don't need an inverter.
Reset on B2 is low on running state and on bootup and reset it goes high.
And iirc ATTinys reset on high on the reset pin.
Edit:
Nope, i remembered wrong, you need an inverter.
My YouTube Channel
Reply 23 of 484, by matze79
The attachment tandy card.jpg is no longer available
Now i can Mix in PC-Speaker 😀
But the adjustment range is too small.
Need to order few parts for testing, maybe i want to try another amp too.
Reply 25 of 484, by CkRtech
Nice work, matze79. Been following this one. Offering up some words of encouragement!
Reply 26 of 484, by matze79
Playing Maniac Manison Intro:
https://youtu.be/c4Go1RSKgpM
- Fixed Mixer problems.
Next, fixing Reset.
Reply 27 of 484, by Jo22
Sounds good. 😀
Reply 28 of 484, by matze79
I will order the first Prototyp PCBs soon 😀
Reply 29 of 484, by matze79
Prototyp PCBs are ordered and hopefully will arrive withhin a few weeks.
Reply 30 of 484, by root42
Awesome. I love these re-engineered cards. Please do post progress!
YouTube and Bonus
Reply 31 of 484, by peklop
Radovan from Slovakia re-eneneered Tandy and Adlib sound cards for PC/104 bus.
For me it is from outer space.
i hope i can repost his prototype picures from Oldkomp cs facebook group. If not, i will delete them.
The attachment 32078662_10213966873598743_7976724128122011648_o (1).jpg is no longer available
The attachment 32090069_10213966873718746_4713226269439819776_o.jpg is no longer available
Reply 32 of 484, by matze79
After nearly 1 Year of work in rare free time i got now the first working PCB, with only one minor Fix in my hands:
The attachment DSC_0070.JPG is no longer available
it worked out of the Box after soldering 😁
Now there is still Stuff todo,
- bracklet design (3D Printer is ready! 😁)
- Firmware improving of the MCU / seems feature isnt working properly on all Machines, remute LM386 on reset. (ISA Reset Signal)
- Writing proper muting utility,
- maybe dreamblaster/pdw will help with his tandy lpt tsr software by adding support for this card too, redirecting 2c0h to 0c0h for machines who can't support the lower adress.
(Pentium and higher ISA/PCI Bridge..)
- intense testing is required, so its time to play some Games 😁
Reply 34 of 484, by dreamblaster
Looks great !!!
Yeah, will try for TSR !
Thanks for your support !
Reply 36 of 484, by root42
Wow! Looks awesome! I want one, too! 😁
YouTube and Bonus
Reply 37 of 484, by matze79
The attachment DSC_0094.JPG is no longer available
The attachment DSC_0078.JPG is no longer available
Slot Cover finished.
Reply 38 of 484, by dreamblaster
wonderful !
Reply 39 of 484, by Jo22
Looks well done!
