First post, by Dirilu
Hallo..
I have made a retro pc with windows 98 and using a MSI GeForce MX 4000 (AGP 8x, 64MB) with newest driver.
But I get this weird color error glitz when I try to play my old original shadow warrior. please see screenshot. anybody know that error.?
I have tried to install duke3d and that game is running perfectly fine.
https://imgur.com/a/WQcFd
Reply 1 of 10, by dr.zeissler
paletted textures?
Reply 2 of 10, by Jo22
dr.zeissler wrote:
paletted textures?
Likely.
I have little exerience with playing DOS games on 98SE (game is the '97 release ?)
but maybe it helps to set the Windows desktop to 256 colours.
I remember Windows XP had an option for that. At least for Windows programs (*.lnk shortcuts).
DOS programs in 98SE used PIF files as program shortcuts and to store settings, right ? 😕
I vaguely remember there was that "dynamic ROM emulation" setting or how it was called.
Disabling that should let the real VGA BIOS do the job.
Edit: http://www.netwiz.com.au/appnotes/2780.htm
Reply 3 of 10, by leileilol
"paletted textures" refers to a 3d acceleration feature which in this isn't relevant as the game's software rendered entirely in 256 colors anyway.
The renderer in SW should initialize the same way as Duke3D does.
And do NOT use "newest driver" when it comes to win98 and the GF2/GF4MX. You'll just get problems. Use an older driver.
FUCK "AI"
Reply 5 of 10, by DosDaddy
Twice have I seen something like this; first time while figuring out how to get SW3DFX to work with an older version of GliDOS and the second time with vanilla sw.exe on XP, which I resolved by right-clicking sw.exe, going to Properties/Screen and changing "Usage" to Full-screen.
Obviously 2 completely different situations, but something's definitely corrupting the palette.
If SW's working ok under pure DOS (you didn't say but I'm assuming yes), then it's got to be a Windows thing, though changing your desktop's color depth as suggested above is quite unlikely to yield the desired results because the video hardware is being accessed in 2 completely different ways if you're indeed using the official drivers. Not that you shouldn't try, though.
Reply 6 of 10, by DosFreak
Make sure you're running the game in MS-DOS, not the command prompt.
Try changing the game graphics options in setup and/or modifying the game config file.
Try running the game with NOLFB.
Make your games work offline
Reply 7 of 10, by RogueTrip2012
I agree on the nolfb.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 8 of 10, by dr.zeissler
though it's cool playing sw in real dos und much cooler with glide-support, but I did not manage to get it to work with dgvoodoo and on the other hand,
playing with win98 and the jonof-port in 1024 is the best option for me. The sound-problems are gone if I use the wdm-drivers in win98 instead of
the vxd-drivers for the ess-solo1.
Reply 9 of 10, by Azarien
Works with nGlide for me.
Reply 10 of 10, by dr.zeissler
What machine and cofig do you have? does it work with dgvoodoo too?
