First post, by Vipersan
I need a bootable setup floppy image of Acronis OS selector.
In order I that I can setup a dual O/S on an early laptop.
I'd guess this was once free and for early versions of O/S.
rgds
VS
Reply 1 of 10, by cyclone3d
Looks like it was included in Partition Expert 9.0 beta.
That is apparently when it was introduced and you would need to buy a copy if you want the non-beta version of 9.0.
Also looks like the beta version had issues with Partition Expert but worked fine if you installed it by itself.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 10, by Vipersan
Appreciated buddy..
at least I know now.
I honestly thought it was a freebie..
you live and learn.
cheers
Reply 3 of 10, by gdjacobs
How early is the laptop?
Reply 4 of 10, by Vipersan
Dell Inspiron 2500 ..
rgds
Reply 5 of 10, by gdjacobs
Ah, well, you should be able to use almost any boot manager. Do you have any unusual requirements?
Reply 6 of 10, by Vipersan
Not really ..other than both OS will need to be seperate primary partitions ..
possibly going to be 98se and ME.
so isolation is key..as both will be fat 32.
rgds
VS
Reply 8 of 10, by gdjacobs
I really like PLOP. Others have recommended the bootloader that comes with XFDISK. That one looks handy as well.
Reply 9 of 10, by Vipersan
Thanks guys ..
I'll run a search for plop ...though in UK parlance Plop is also excrement ..so gawd knows what the search will reveal 🤣
Reply 10 of 10, by gdjacobs
A search for "plop bootloader" should cut it down.
