Reply 1840 of 5225, by xjas
- l33t
wrote:I note you were playing an MP3 on this, how are the speakers holding up?
I have a couple of similar model iMacs and when I pulled one out of storage a few months back I discovered a nasty problem - the speakers in these have a tendency to rot. I was playing music back on mine at normal volume levels for a while, when suddenly the speakers started blowing out dust & debris through the front, followed by what can only be described as farting sounds as the speakers' foam litterally crumbled away and the cones started rattling loose.
Quite a common issue with these old iMacs, so something to watch out for.
They seem fine, I didn't crank it but they played nicely. This one probably spent most of its life in a climate controlled lab; it was kind of dusty but otherwise well kept. I'll keep an eye on them though.
@CJ_Reha - that 5x86 desktop case is awesome, love the design detail. Great job saving that lot!
