First post, by jamesbeat
I watched Phil's excellent YouTube video on his 4-in-1 Super Socket 7/K6-3+ ' time machine', and I'd like to do something similar.
The part I am most interested in is the 386 and 486 performance configurations.
I'm not too bothered about going higher than a Pentium, as I have a PII machine that can take care of that side of things.
What I want to know is, can I use a regular (not super) socket 7 motherboard and a K6-2+ CPU for this?
I understand that the processor won't run as fast in the non-super board, and that's fine.
However, I'm concerned that it will run too slow even to get the proper 386 and 486 performance when I disable the caches.
My first ever pc was a socket 7 with a K6-2 in it, but that was a LONG time ago, and I have forgotten pretty much everything I used to know about pc's of that vintage.
If I put a K6-2+ in a regular socket 7 board, will the 386 and 486 parts of Phil's setup still work properly?
Reply 1 of 12, by lazibayer
I don't see why not; Phil simulated the 4 modes with 66MHz bus, so I think any socket 7 board can replicate the same experiments.
Well, not exactly any board; the board must support low core voltage and have BIOS patched for k6+ CPUs.
Reply 2 of 12, by The Serpent Rider
You should consider VIA C3 option.
Reply 3 of 12, by jamesbeat
I read about that, but unfortunately my PII motherboard does not have an option in the BIOS for disabling cache.
Reply 4 of 12, by Baoran
Disabling cache in PII isn't very useful anyway. It makes the cpu way too slow. It isn't same as with socket 7 systems.
Reply 5 of 12, by jamesbeat
Thanks for that link, it is really useful.
Turns out that the board I had my eye on would not work.
It looks like it's going to be tricky finding a suitable board at a sane price.
Reply 6 of 12, by brostenen
Near impossible. Getting a Pentium-1 system is much more easy these days. Even a 486 is sometimes cheaper.
3 complete AT systems might cost you the same. The major drawback is how much space they take up.
Reply 7 of 12, by gdjacobs
I'd seriously look at the Ezra route. My personal experience is that S370/Slot 1 boards are far more common.
Reply 8 of 12, by lazibayer
I reckon jamesbeat was talking about disabling the cache of a C3 in his PII board.
You can disable the cache in C3 by using SetMul.
Does your P-II board support C3? You might get a via C3 + 694x board combo for cheap and not need a P-II system anymore, but I am not sure if a 200MHz Cache-free C3 is too fast for your 386 emulations.
Reply 9 of 12, by lazibayer
jamesbeat wrote:
Thanks for that link, it is really useful. […]
Are you in the US? Right now there is a TXP4 and an SP97-V board with reasonable price on ebay.
You might have to go thru that list and search for each individual board. My experience told me that the more the seller knows about the board, the more accurate the description will be, and the higher the price. My best luck of getting (super) socket 7 boards are from scrappers. For example, HP used to use ASUS motherboard in their systems but the seller will just label it as "HP logic board model number 1234-5678".
Reply 10 of 12, by jamesbeat
Well, it seems as though there may be a change of plan....
At my job, we are currently putting together skids of old pc equipment to send off to the recycler.
I'm allowed to take anything I want before it goes, so today I went into the warehouse with a screwdriver to salvage floppy drives etc.
There was a new beige machine I had not seen before - it's a Digital server, and the case badge tells me it's a Pentium Pro!
I have rescued it from the skid, but I haven't been able to get the lid off because it's locked.
I'm going to try and pick the lock tomorrow lunchtime, and I'll see what I have.
A quick look at the manual appears to show that it is SCSI only, but maybe i can fix that with a PCI card.
I'll post a new thread when I know exactly what I have.
Reply 11 of 12, by lvader
I’ve done K6 III+ and Via C3 builds, but actually found a good old Pentium MMX 233 to be the most flexible, you can get very smoth transitions bewteen low end 386 up to P233 performance.
Reply 12 of 12, by gdjacobs
Agreed, the PMMX has more versatility within it's performance range.
Let's benchmark our systems with caches disabled
