First post, by Sev80
Sev80
Offline
Hello,
i have a VIA VX98 board, last time i used it, it worked great, this time I'm trying to use it with the same keyboard and it's throwing a "no keyboard present" error on POST. The battery is new and i tried reflowing the solder joints on the keyboard connector, but no dice.
Upon power up, i see that the keyboard lights flash but nothing else works. I did verify the keyboard, which is an AT one, does work on other motherboards... Any help would be appreciated!
