Industrial PC (EPSON IM-425) as Retro Gaming Device
Reply 20 of 64, by derSammler
Did some more tests and I'm quite impressed. Everything worked from the outset. Upgraded RAM to 32 MB -> no issues (though single bank/dual bank must be correctly set via a jumper, 32/36-bit in BIOS - no auto-detection), sound card works fine, too, incl. the S2 over MPU-401. Apart from the rather complex BIOS, there's nothing different to an ordinary PC. May get one or two more of these. 😀
Reply 21 of 64, by matze79
did you also purchase the 24v power supply ?
Reply 22 of 64, by derSammler
No, I built my own. 7€ for one from Pollin and some minutes soldering the correct connector, which I already had.
Reply 23 of 64, by derSammler
Just for the record: IDE to mSATA adapters do not work in the unit. Auto-detect fails and entering CHS manually doesn't help either. It sees the disk, but won't ever see any partitions, nor can any changes to the drive be made. Didn't even help creating the partitions with a different PC.
Reply 24 of 64, by derSammler
Ok, now *that* works! So I can even get 16 GB by using two 8 GB cards without hitting the BIOS limitation. 😎
Reply 25 of 64, by derSammler
Up and running. 😀
Reply 26 of 64, by Scubs
derSammler wrote:
Pimped top cover. Everything looks better with carbon imitation. 😎
Around my parts we call that redneck carbon fiber. Nice system by the way.
Reply 27 of 64, by derSammler
Custom front panel is ready for printing. 😁
Reply 28 of 64, by derSammler
Two more, just in case... 😉
Reply 29 of 64, by derSammler
Almost done now.
Reply 30 of 64, by BinaryDemon
I would have to paint the white faceplate on floppy drive. Other than that, it looks great. 😀
Reply 31 of 64, by derSammler
More pictures.
Reply 32 of 64, by derSammler
A few more pics showing the internals. Hardware-wise, it's done now.
Reply 33 of 64, by squiggly
It almost looks like it would fit in two 5.25 inch drive bays. That would be pretty cool.
Reply 34 of 64, by derSammler
It's a bit wider that a 5.25" bay, sadly.
Speedsys results.
Reply 35 of 64, by CkRtech
Pretty impressive.
Reply 36 of 64, by derSammler
I'm also very pleased with how it turned out. This is by far the coolest 486 in my collection now, and also the fastest, and of course the smallest. 😀
Reply 37 of 64, by mcobit
I have bought one, too. But the universal Win3.11 svga driver doesn't work. Did you find any Win3.11 VGA drivers for it to display 256 colors?
Does Windows 95 have drivers for the graphics chip out of the box?
Reply 38 of 64, by derSammler
The graphics chipset was detected by Win95 but the installed driver did not work with more than 16 colors. I then selected a different but compatible driver that Win95 had built-in. It's just called "Chips & Technologies Super VGA". With that, I can use 256 colors at up to 1024x768.
As for Win 3.1x, no idea. I have a second unit that has DOS 6.22 & Win 3.11 installed, but I did not bother installing a display driver (yet).
Reply 39 of 64, by le Franz
Hello
Good machine .
You write PnP not supported, Do you have a sound card PnP ? And do you think be a problem with sound blaster 16 PnP ?
Or he works only with sound card with jumper config ?
Sorry for my bad english
