First post, by Dracolich
Hello, everyone. I hope this is the right forum for this question.
On my i430TX rig I've had Warp installed and running on a Quantum 1.0GB disk for a while. I did not have the boot manager installed and it was a hassle to switch between the OS2 and DOS disk drives to multiboot. Thus I made raw backups of the disks and continued playing with the OS2 as a VM in PCem. It worked fine in the VM and the specs were very close to my real hardware. I could also write the backup back to the hd and it would work on the real hardware.
Recently I got a Syba CF->IDE adapter to replace the primary master disk in this computer. Now I have reduced the DOS installation to <1GB and transferred to a CF and it works nicely. Windows 3.11 has a small quirk that sound effects play too fast. The exit sound had to be disabled as it caused Windows to hang when exiting. I have also installed Puppy Linux 2.17 to another CF and it works fine.
OS/2, however, is giving a fit. It displays the splash screen but freezes. I can press Alt+F2 at the "blob" to see drivers while loading and it is hanging on I2OSOSM.ADD. I came across a thread on this site where another user had the same problem but it was not solved. There are only a few differences between the configuration of the hardware and the VM.
Hardware VMi430TX i430VXintel 233MMX AMD 233MMX128MB RAM 128MB RAM1GB CF IDE0 1GB IDE018GB IDE1 CD-ROM IDE1Zip100 IDE2 2GB IDE2CD-ROM IDE3 empty IDE3Floppy A, B Floppy A, B2x USB 1.0 USB N/A4MB Virge/GX 4MB Virge/DX4MB Voodoo1 4MB Voodoo1SB16 SB16DFE530TX+ NET N/A
Both the 18GB IDE1 and the 2GB IDE2 are FAT32 non-booting disks. I have tried disconnecting the 18GB disk and the Zip100; and have tried swapping the Zip and CD-ROM. I wonder if it might be reading too fast. I tried disabling UDMA for it but that didn't help. One thing I haven't tried yet is arranging the CD-ROM and 18GB disk to match the VM positions. I know OS/2 is picky, but could it be so much that it complains if non-booting drives are rearranged? I hope it can be solved without reinstalling. I can attach the CONFIG.SYS if anyone has ideas and needs to see it.
