Reply 20 of 57, by j^aws
- Oldbie
wrote:I'm trying to build a machine that can be slowed down to replicate a 286, 386, 486 (and maybe a Pentium, though this is less important because I already have a Pentium Pro machine).
8088 would be awesome too, but I don't know if that's possible.
A smooth range from 286 to P1 is possible with Socket 5/ 7 boards with additional slowdown parameters, such as ultra low FSBs (33MHz or slower), forced Write-through L1 cache policy and Turbo/ De-turbo functionality.
Using a typical VIA C3 or SS7 K6 build won't slowdown into 286 territory. You might get better luck with a VIA C3 Nehemiah, but you lose smooth scaling.
Getting into 8088 territory is possible, too:
WIP 2: The 6-in-1 Turbo-switched Socket 7 - from XT to 500MHz; dual Tseng powered...
Scaling graphs:
download/file.php?id=33939&mode=view
download/file.php?id=34139&mode=view
