First post, by BetaC
So, I am in the hunt for a graphics card to go in my general purpose XP build, and am wondering if anyone knows what cards actually make the Volumetric Shadows in Jedi Knight, and Academy by extension, actually render correctly. Searching for this elsewhere leads me on a goose chase with people mostly complaining about the problem on newer hardware.
Reply 1 of 18, by leileilol
r_stencilBits 32
cg_shadows 2
The stencilbits part is important. This applies to many (but not all) idTech 3 games.
The shadow code was originally for Quake3 which was coded mainly on Riva TNTs. Anything supporting a high enough stencil buffer should work.
Its artifacts (which there will be!) are not video card specific - it's due to how the shadow's calculated from the local model's position on the map's lightgrid. Unlike Doom3, there's no real light positions to work with. The shadows don't really have any fading falloff either. In addition to that, some idTech 3 games have a hardcoded surface vertices limit per surface and will skip drawing a shadow if the model is too complex.
Reply 2 of 18, by BetaC
I can safely assume that the range of cards that I am looking at (Either the 6xxx or 7xxx range from Nvidia, since they natively work with Republic commando's Bumpmapping without mods) should work with it. thanks for the help.
Reply 3 of 18, by Fusion
leileilol wrote:
r_stencilBits 32 cg_shadows 2 […]
r_stencilBits 32
cg_shadows 2
I thought 8 was the max setting for stencilbits.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 4 of 18, by leileilol
IIRC it was for the sake of buggy drivers. r_depthBits 24 and r_stencilBits 8 would be the ideal cvars and I was tired when I wrote that so it could be a misremembering. I do recall some overlapping artifacts on a certain older card with it set to 8 though.... it's been a very long time since i've tried the hacky stencil shadows
Also it should be noted that JK2MP does not allow cg_shadows 2 cue to potential cheating potential from the casting. cg_shadows 3 (a solid black shadow on the floor planes only) is still allowed however. You can force cg_shadows 2 to work by setting developer to 1.
Reply 5 of 18, by dr.zeissler
can you post some screenshots please.
Reply 6 of 18, by leileilol
you say that like it's a fake effect 🙄
The attachment shadows.png is no longer available
and here's illustration of what happens when you've got too many verts and it skips. Note the lack of shadow for the body and the drillbit
The attachment shadows2.jpg is no longer available
cg_shadows 3 (seen in q3's intro video) only does flat floors, so slopes don't get shadowed
The attachment shadows3.jpg is no longer available
Reply 7 of 18, by gdjacobs
Those pictures!!
What kinda games you playin?
Reply 8 of 18, by infiniteclouds
http://www.rage3d.com/board/showthread.php?t=33612377
its not the v-card guys... i have a ti4600 same thing. i just use r_shadows 2. I think the problem is actually (ironically enough) only with the cards that support higher end shadowing effects. i dont hear these things from TNT 2 of gf1/2 owners. hmm.
Sounds like a Geforce 2 might be the fastest NVidia card that can properly display them.
Reply 9 of 18, by leileilol
Probably due to the r_primitives part. Overload the extensions list (which nVidia and ATI very much did then) and it won't find compiled vertex arrays and it'll be slower by default unless you set r_primitives 2. It makes me wonder how much benchmarking misinformation that detection mistake caused........
Reply 10 of 18, by infiniteclouds
I have no idea what that means -- but when I read "by default" and "set <setting> it leads me to believe that we have have these shadows working correctly on later cards if some tweaks are made?
Reply 11 of 18, by DracoNihil
"Riva TNT"
Again I hear that card and realtime shadow usage in the same subject...
Unreal had a experimental TNT specific renderer patch to enable similar shadows, and they look really hackjob and ugly. Seeing this in the Q3 engine doesn't give me any high hopes of this being a worthwhile option to pursue given the limitations. I'll keep these CVAR's in mind if I ever get Q3A and Jedi Academy reinstalled someday.
32-bit stencil buffers still relevant these days by the way?
― Κυνικός Δράκων
Reply 13 of 18, by Fusion
It looks ok in motion, but it does hit the framerate pretty hard. You will always see odd artifacts with that setting.
Reply 14 of 18, by BetaC
Sorry to semi-necro this thread, but I am back from vacation, and have everything back in running shape. I actually have examples of what I was mentioning by the shadows looking "wrong"
This first image is most definitely an error.
While this one just shows off how they look when things aren't going that wrong.
Reply 15 of 18, by Scali
That's interesting actually...
Did anyone ever tried to make a 'filter' for the extensions list to circumvent this issue on newer hardware?
As in: you put a shim between the application and the OpenGL driver, and the shim filters the actual extension list down to a subset relevant to the application, so that it will not be overloaded?
Reply 16 of 18, by Fusion
That is the best you'll get BetaC. IMO, Q3 and Elite Force are the only games that you can use cg_shadows 2 and not have it look too glitchy. You'll still notice the errors sometimes but being such fast paced games it makes it easier to ignore.
Reply 17 of 18, by infiniteclouds
By the way, I had this game when it came out... I think I was running a Geforce 3 at the time and this shadow mode was borked Day 1. I'd like to know what these shadows look like (same sceens posted) when they are not glitched... because I've never seen that.
Reply 18 of 18, by leileilol
You'll never see them unglitched because this is a really really really old attempt at impractical stencil shadows left in the engine since 1999. It's shadows casting from approximated light positions from models' local space on the map's precompiled lightgrid. It will never look perfect. I don't know how many times this bears repeating...
