Radeon 7000 series gfx-Cards (Retro-Build)
First post, by dr.zeissler
sorry a bit off-topic.
I have to uncheck fog in Turok1 and Turok2 otherwise I get extreme slowdowns with my R7000-PCI.
Installing the RageTweak 3.9 and checking the "Table Fog" there does not help. Any ideas?
http://www.majorgeeks.com/files/details/rage3d_tweak.html
Reply 1 of 36, by swaaye
Yeah that was totally off topic. Make your own thread instead when you want to change to an unrelated topic.
Reply 2 of 36, by weldum
which driver are you using? maybe using a date-aproppiate driver will solve things
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 36, by dr.zeissler
The last driver available (6.2). These massive framedrops are also when using a glidewrapper (dgvoodoo) and playing titles like "ignition"
The game is super-smooth and fast but if fog-features are used the framerate drops near zero.
Reply 4 of 36, by weldum
Should try a driver more close to the year the game launched, is common that when newer cards are launched, the drivers are more optimized towars newer hardware
Reply 5 of 36, by dr.zeissler
Mostly I read that ATI-drivers were bad if the card is new, so I went for the newest supported driver.
I will checkout an early one 4.x instead.
Reply 6 of 36, by weldum
be sure to try it, also which os are you using?
Reply 7 of 36, by dr.zeissler
Tripple-Boot:
- Dos/Win1x/2x/3x/Gem/Geos (still need to patch the win3x vesa-driver for 256colors)
- Win98se DX8.1
- Win2000 DX9
The R7000 is a card that has all important modes centered on analog vga on the tft. (VGA-Text/EGA-gfx/VGA-gfx).
The card is quiet and has a very clean and sharp output. S3tc does work out-of-the-box on ut436 (with hirestextures).
The R7000-Techdemo works, but freezes after a short while. Regardingless it looks like the card has some sort of
pixelshader (reflections on the floor) but none other game can use them, but I am not shure about this.
I have checked out a lot of cards and this r7000 was the best so far.
Reply 8 of 36, by weldum
everything looks fine, the thing that's suspicious is the techdemo freezing
do you have any way to measure the heat in the card? other than touching it
Reply 9 of 36, by dr.zeissler
It's a driver issue. With Win98se it freezes even if a big fan is mounted on the cooler so the gfx-card stays cold.
In win2000 it works better but the framerates are low. The res is to high for that gfx.
Reply 10 of 36, by weldum
still, it should not freeze up. to me everything is because of a driver issue, try downloading the first available driver for that card in each OS and see if it's an improvement, if you can't find it, tell me and i help you in the task
Reply 11 of 36, by derSammler
It's probably because the 7000 can not do that in hardware and rendering those effects in software gives a massive drop in fps. The 7000 was very, very low end.
Reply 12 of 36, by matze79
Yeah the Radeon 7000 is a cut down Radeon DDR..
hold back by 64bit memory bus..
The Radeon DDR is superior to it.
Can't confirm any slow downs, just a slight fps drop.
Using Radeon DDR.
I also own a 7000 PCI, so i can test it if you like.
I simply would drop in a Rage 128 Card if you like Table Fog.
It looks better on Rage.
Reply 13 of 36, by dr.zeissler
Please do some testing. I checked out the Cat 4.2 and 6.2 it's the same. Other games perform really good with that card. (Kingpin, UT99, etc.) S3tc looks really good on R7000.
Turok1: D3D
- First massive framedrop is at the end of the Logo Animation.
- Second is after the menu is visable and the statusbar (highlight of the menu) is "pulsing" => look at the background.
- If i disable "fog" the framedrops are gone and the game is ugly.
I discovered only turok1/2 to be problematic. (And of cause glide-emulation with dgvoodoo).
Doc
Reply 15 of 36, by weldum
that's weird, i thought that the radeon series had table fog emulation, you may be looking for some card that has support for that in order to play it
by the way, nice collection, althrough i can't load the pictures in full detail, my internet is going slow lately.
Reply 16 of 36, by dr.zeissler
strange things happen...now the radeon ark demo is working. don't know why.
but I had to reinstall the latest driver (6.2 Catalyst)
Reply 17 of 36, by weldum
that's really strange, great but strange
i've found this, it may work, have you tried it?
[HKEY_LOCAL_MACHINE\Software\ATI Technologies\Driver\0000\atidxhal] […]
"DisableHierarchicalZ"="0"
"EnableWaitUntilIdxTriList2"="1"
"Vsync"="0"
"DitherAlpha"="1"
"AntiAlias"="0"
"AntiAliasRatio"="512"
"ZFormats"="15"
"ExportCompressedTex"="1"
"TableFogEnable"="1"
"WFogEnable"="1"
"ZFogEnable"="1"
"FastZClearEnabled"="1"
"DisableHyperZ"="0"
"TCL"="1"
"TCLEnableVertexBlend2Optimize"="1"
"TCLEnableVertexBlendUseProjMat"="1"
"TCLEnableBackFaceCulling"="1"
"RasterGuardbandEnable"="1"
set to 1 the "TableFogEnable" thing
Reply 18 of 36, by dr.zeissler
No, but I think these option are exactly what the ragetweaker uses.
Reply 19 of 36, by weldum
is that, or using a nvidia card, also you can use a 3dfx, i think a savage 4 also works, you may need to do testing
i have some cards, but all the games i have doesn't use palletized textures nor table fog, so i can't help you more
