McBierle wrote:Sorry for digging out this old thread, but i had time to play around.
S1-4 are indeed "fixed" on 5v but i measured and it seems […]
etherlore wrote:McBierle wrote:It seems i have the same one. It is a Socket 3 board, i'm using an i486DX4-100.
I noticed you are running with S1, S2, S3 and S4 open, which according to the print on the board would give 5 Volts. Aren't all DX4 in the 3.5 V range? Is your DX4 fine with the higher voltage?
I have a DX2-50 on mine, but am considering upgrading to a DX4. I figured I would have to try and close S1-S4, so I'm curious that maybe I don't have to?
S1-4 are indeed "fixed" on 5v but i measured and it seems this board has an voltage detection. Intel/amd dx4's run at 3.X V.
I soldered jumper pins on some places so i could chose cyrix as i now have an TI dx4 which if i'm right are cyrix cpus. To my surprise it runs at 5V. Does cyrix not support this voltage detection stuff?
As i wrote earlier amd dx4 is idetified as dx2-66. But after doing some benchmarks it seems to run similar to a intel dx4.
Another thing is that it seems the jumpers for 2.0x / 2.5x / 3.0x have no effect, the cpu choses its own multiplier.
Thank you for the update, I may look into getting an intel DX4 now.
Some other things I discovered with this board recently,
Using an intel DX266 SX955 (P24D) with the jumpers set according to the middle column, sometimes produces bad audio distortion in some games. I got around this by setting the jumpers according to the left most column (pictured)
The attachment IMG_1498.jpeg is no longer available
, which makes the board recognize the CPU as a "80486DX2S", rather than a "P24D". This may or may not be because of an issue with how the board handles CPUs with write-back cache functionality, like the P24D.
I also discovered that this board does support large hard drives, if set to "LBA" configuration in the bios, without changing any of the cylinders and heads etc. This has allowed me to use a 4GB drive on this system, albeit I had to partition it into two 2GB partions. The hard drive will not show up correctly during POST, in fact my 4GB drive displays as 96MB, but it is still recognized fine by FDISK as the full size.
