First post, by jheronimus
- Oldbie
Hi, all
Today I got myself an InWin S500 ATX case with an FSP ATX350F PSU (originally came with a Celeron D) and decided to finally give my Asus P/I-XP6NP5 board a test. Here are the full specs:
- Pentium Pro 200 Mhz;
- 64 megs of EDO RAM in 4 sticks;
- Matrox Millenium videocard.
The problem is that it doesn't POST and there is no video output. The PSU fan is working, the CPU gets hot, the disks spin up (disconnected them for now) What I've tried so far:
1) checked all the jumpers. Originally the board was set for 3.5x instead of 3x, meaning that the CPU would be running at 233 instead of 200 Mhz;
2) tried another videocard, though I know this Matrox to be working. Same goes for RAM (used it in my Socket 4 board);
3) tried to change the "3.3v power source jumper setting" from PSU to onboard and back;
4) changed the BIOS coin battery;
5) reseated all the front panel cables;
6) tried another CPU — another PPro@200.
I'm not too experienced with ATX and I'm out of ideas. Then again, I don't have any guarantee that the motherboard is working or that the PSU isn't too modern (here are the specs).
What else should I try?
