First post, by MKT_Gundam
Its my first time to find a 386 motherboard without barrel battery leaking.
I need some help to indentify this motherboard.
386_mobo2.jpg%22%20alt=%22386_mobo2
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 10, by noshutdown
its just a very common layout used by many brands which can't be identified.
i have a similar board in orange with soldered cpu, which is unfortunately defective and wouldn't work with 128kb cache.
Reply 2 of 10, by Tiido
There's sometimes some text in the PCB in the back near power connector.
Reply 4 of 10, by MKT_Gundam
ReL wrote:
Thnaks for the Help. My board dont have the jumpers headers 7,8 and 9 (for cpu frequency) but . I just have a spare amd 386 dx 40.
Reply 5 of 10, by ReL
The only way to switch is to use a soldering iron 😀
Reply 7 of 10, by MKT_Gundam
The jumper setting for cpu shows 50m, 66m and 80m (without the "Hz").Also there no option for cpu without jumpers. The 80m (or 40m?) needs at least the jumper n.9 closed
Reply 8 of 10, by MKT_Gundam
How should I use the multimeter to check the polarity of the external battery header?
Reply 9 of 10, by Tiido
Connect one probe to the chassis (or ground pin on the power connector or shiny part around screw holes) and other to the edgemost pins on the header, if you get a match you've identified the negative pin, other end is the positive.
Reply 10 of 10, by evasive
I found a possible duplicate in TH99
https://stason.org/TULARC/pc/motherboards/U/U … 86DX-33-40.html
Something similar:
https://stason.org/TULARC/pc/motherboards/S/S … OT-317-VER.html
