First post, by moturimi1
Hi, I have received the MicroWave PC extension.
Unfortunately a coil is missing and I do not know which specs it have (µH, mH?). I think it is used to filter the digital signal.
Can a vogons user help me out? Would be cool!
The copper coil is show on this picture: (bottom left)
http://studiorepair.com/gallery/Waldorf/Micro … 0808106793.html
Reply 1 of 20, by hard1k
I have this unit in my collection, however it is in Russia while I'm in Argentina. I'm planning a short visit for July, if you give me an exact indication of how I get the needed value(s), I'll do my best to help.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 2 of 20, by moturimi1
Hi thanks a lot.
I was able to repair the device, but I do not know if I used the right device. I soldered this one in:
https://www.reichelt.de/stehende-induktivitae … gKTPvD_BwE&&r=1
The Waldorf Micro Wave PC works when connected to the EWS 64, I read that it is also possible to use it with a PCI sound card: DMX 6fire 24/96
In this case it seems to be necessary to connect a converter board:
http://terratec.ultron.info/Audio/DMX6fireLT/ … ckzettel_DE.pdf
I ask myself why this board is necessary.
Reply 3 of 20, by delon
Sorry for the awakening this topic but does anyone here still have the Microwave PC? I want to rekindle my love for it but I cannot find the ribbon cable(s) to connect it to the DMX 6Fire. These are now impossible to find (unless you buy an overpriced EWS ISA bundle). I wonder if the ribbon-like one can be DIY'd from a 26(?)-pin ribbon cable if you have the pin layout (which is, again, not documented anywhere on the net). As for the candy strip-like one, I don't know...
Any ideas?
Cheers,
delon
Reply 5 of 20, by delon
hard1k wrote on 2022-10-28, 08:26:
Hi Delon, I have one, please drop me a line in December - we are moving now, so everything is packed and stored.
Thanks, I will surely do!
Reply 6 of 20, by stmill1
Hi, Delon
You can use a regular 26 pin flat cable
Anyway you will have to customize it to have the 2 twisted wires as shown. connected pins are identical on both side so I don't know why they did that..
I can't try with a standard 26pins cable as I don't own one.
You can check here too : http://studiorepair.com/gallery/Waldorf/Micro … 0808106803.html
I don't own adapters shown on the picture, never had. The module is working fine without
Works in windows 7 (even whenn you use an external PCI adapter
Anyway, in windows 10/11 control panel is not stable and microwave software is not alway loading properly.
Stef
delon wrote on 2022-10-28, 08:17:
Sorry for the awakening this topic but does anyone here still have the Microwave PC? I want to rekindle my love for it but I can […]
Any ideas?
Cheers,
delon
Reply 7 of 20, by delon
stmill1 wrote on 2022-11-12, 15:12:
Hi, Delon
Hi Stef,
Sorry I was totally away from the net (work & illness).
Amazing info you posted here, thank you! Yes, I knew the Studio Repair site but I couldn't see on the pictures how the individual pins were interconnected (and he didn't reply to my emails). I am still confused as on your picture, the pins are identical yet I clearly remember the MWPC manual states that you shouldn't use a standard 26-pin flat cable as it may damage equipment...
I remember the other (candy-coloured) ribbon cable was used for analog inputs. I might not use analog I/O but I do need MIDI input. Do you miss any functionality by using the flat cable only?
Thanks,
delon
Reply 8 of 20, by delon
Meanwhile, I checked eBay and there are a couple of EWS XL's for sale w/ frontbays. I attached pictures about them and I see no twists in their cables. I know that you can attach an MWPC to an EWS XL using the same cable so theoretically, a simple 26-pin flat cable should indeed work with the DMX 6Fire as well. Am I right?
Reply 9 of 20, by stacker139
Hi Delon
PM sent to you
Project: SB-XXXL, Extensive Sound Cards System
Reply 10 of 20, by stmill1
Hello
Sorry for the late reply too busy too on other topics
I've always used the MWPC with this special cable event on the EWS64XL.
Reply 11 of 20, by stmill1
By the way
I'm actually finalizing 2 vintages PC machine with EWS64XL + pentium 3 W98 on SD64GB installed, fully functionnal.
So if anybody is interested just MP me !
I will post the full description in another thread, but I need to find the right one.
Stef
Reply 12 of 20, by stmill1
delon wrote on 2022-12-19, 11:48:
Hi Stef, […]
Hi, Delon
Hi Stef,
Thanks,
delon
Hi Delon, did you solve your qyery or do you want me to check again the calbe and try to help you building a new one ?
Reply 13 of 20, by delon
stmill1 wrote on 2023-02-01, 11:23:
Hi Stef,
Sorry, I was busy, too. Yes, I am still interested! Sending PM...
Reply 14 of 20, by dionb
delon wrote on 2023-02-15, 08:06:
Hi Stef,
Necro bump here:
I've also gotten myself a Microwave PC and a 6Fire and would like to be able to connect them. The photograph posted by stmill1 it tantalising, but I can't figure out exactly what is connected to what. Did you ever figure this out?
Reply 15 of 20, by Peter djpj
dionb wrote on 2025-02-13, 09:26:
Hi Stef,
Necro bump here:
Hello hope you still are active with your Microwave PC, I got mine working after years. Bought it original with an EWS64 XL.
Later on I bought the DMX6Fire LT, and had it working .
Now I rebuild an old I7 pc, with windows XP, and after a while, while playing loaded .mws soundsets, first the analogue sounds via the headphone and speaker out starts dropping and when i switch to digital out, the same happpens some minutes later, and after a while the whole soundcard stops working,
When I disconnect the MWPC, and play music it has no problems.
Could one of the capacitors be defective ? I cleaned the circuitboard with isopropyl and checked it with a optivisor but could not find any visual problems.
Would love to have it working normally, as it is a great sounding piece of kit.
Reply 16 of 20, by Peter djpj
Peter djpj wrote on 2025-08-31, 08:55:
Hello hope you still are active with your Microwave PC, I got mine working after years. Bought it original with an EWS64 XL. Lat […]
Hi Stef,
Necro bump here:
now i tried the PC again. i can't get the MW sounds over the analoque circuit, yesterday it did work, it only works over the digital out, but it stutters a lot.
Reply 17 of 20, by dionb
That could be bad caps, yes.
Not had much time to play around with my stuff over the past months I'm afraid.
Reply 18 of 20, by Peter djpj
dionb wrote on 2025-08-31, 22:39:
looks like it might be the caps;
sunday i re-installed Windows XP Pro, and yesterday, i did a 'cold start' on this PC, the first five minutes i had flawless sound on the analoque, and the digital output,
but after a few minutes parts of the sound started missing, and soon the analoque sound stopped, i then switched to the digital output, i had sound but soon also the sound was gone.
anyone have any idea which capacitors could be the problem? and what the values of the capacitors are?
here is a good link to the layout of the board;
Reply 19 of 20, by dionb
There are 8 electrolytics there, one on the left by the voltage regulator, five around the stereo amplifier and two more separate ones.
Given your symptoms also occurring with digital audio I'd suspect the one by the voltage regulator first, but tbh, if one has gone it's generally good practice to replace all of them. As for the values - you should be able to read that on them.
On mine I read:
1x 10V 220uF (SSL FF - this one's behind the regulator)
1x 10V 220uF (different brand - ELNA RE2 series)
2x 6.3V 10uF (SSL S)
2x 35V (!) 47uF (SSL FK)
2x 16V 470uF (LCC THGS)
SSL is Sound Storm Laboratories, manufacturer of high-end electronics for audio equipment. Unfortunately they don't make these little ones any more and I can't find exact specs.
ELNA is a Japanese company, still makes these devices and there are datasheets available: here
THGS is a Thomson brand, LCC one of their cap lines. Thomson went through a whole range of split-ups and mergers (I currently do business with one of their former bits that is now Vantiva...) and I'm not able to find datasheets here either.
I'm pretty up to speed about caps used in general computing, but audio is a bit of a niche specialty and I'm not so confident about it. People like keropi and Tiido know vastly more and would be able to give better advice than 'just look for other decent caps with same capacitance and voltage'
