First post, by Grub3r
Hi all.
I have a mb with p120 which I want to upgrade with p200mmx
As now the board is configured with single voltage jumpers.
Im unsure if the new cpu is single or double voltage.
Would you explain what the difference is.
P120: sy062, a80502120
P200mmx: sl27j, fv80503200
I can also see that the voltage was set to 2.8 for p120 which is wrong?
Thanks.
