Update. Did a few more tests. The other graphics card failed to display a picture @25MHz.
On neither my CRT, nor my NEC LCD, I was able to see anything.
Here's the CRT out of range message again..
- funnily, the frequencies are the same as provided by the Winbond card..
The attachment othe_hgc_25mhz.jpg is no longer available
dionb wrote:Wow, it does indeed work!
Colour in photographs is always tricky. I would expect it to be green mono,
but some screens detect mono and output white instead. These could be either, what is it like iRL?
I wasn't sure if would work or how it would look, either. I'm glad VGA can indeed work with a single RGB channel.
Thanks for the tip, again! 😁 In real life, the greens look a bit more vivid.
The attachment herc_25_msd_moregreen.jpg is no longer available
root42 wrote:Awesome result! Back in the day I would never have thought this is possible! Really great!
What happens when you hook it up to an LCD with VGA input? My Philips LED LCD screen so far works with any VGA resolution I can throw at it.
Thanks! ^^ I had my doubts, if it would work with my monitors at all. If I hook my NEC MultiSync LCD 1550ME,
I sadfly get an out of range warning.. Also, graphics mode didn't work so far. Perhaps the software expects 50Hz sync, not sure.
Anyway, it works just fine for text adventures, Tetris and so on. Since my PC/XT clone has CGA on-board, this is not THAT bad.
For other people with a dual graphics setup or some ancient machinery, this Hercules (or rather MDA) "hack" is good to know.
https://youtu.be/j1N_sP8MshY
Kubik wrote:And you know there's an active Hercules/CGA/MDA/EGA to VGA converter?
https://sites.google.com/site/tandycocoloco/m … -cga-ega-to-vga
But still, a really great idea!
Hi! Thanks for your reply! I'm not sure if you were writing to me or root42, but as far as I'm is concerned, yes I do. 😀
However not for very long (just since about two weeks or so), also I don't know how to construct that device. 😅
Say, does an universal chip programmer like the TL866/G540 would wo or does the project require an FGA progamming device ?
