First post, by GabrielKnight123
I have installed Dos 6.21 with Ontrack Disk Manager to get 4 x 2GB partitions but when everything was made it used default names for the root or volume names is there a dos command to rename these or do I have to reformat them and name them after?
Reply 1 of 2, by PARKE
The attachment label.JPG is no longer available
Reply 2 of 2, by brostenen
Normally you just go to the drive and use the command "label".
