First post, by Hamby
- Oldbie
What happens if you plug a (in this case 486) CPU card into the ISA slot of another computer?
Say I have a K62-300 (cause I do) with some ISA slots... what would happen if I plugged a 486 CPU card into one of the ISA slots?
Will it fry my K62?
Will it fry the 486 card?
Will it sit there doing nothing?
Will it function as a separate computer?
Will it communicate with the K62?
I've seen several of these on ebay (seldom do I see ISA backplanes, though) and started wondering if they could be used as secondary systems, like the 2088 card for the Amiga.
(I know the answer is probably, "are you out of your mind?" but I still had to ask.)
