Reply 60 of 100, by misterjones
- Member
wrote:Is yours an OEM card?
It is. It's an IBM OEM card. FRU 22P0704
That's not that bad, actually it is about what I expected. 32MB version should be able to reach around 36FPS with those settings, and probably 40fps at 1024x768x16 which is roughly Voodoo 3 2000 levels of performance - that is a solid in my book. I have a 32MB version of this same card and look forward to testing it in my GX110 with a 1GHz P3 CPU myself.
Considering that, according to the Anandtech test, the G400 is able to hit 51fps with a P3-600 under Win98SE I would expect that the G450, which is supposedly only a tiny hair slower in games, would be able to muster something over 40fps, especially when paired with a faster processor. But... I'm going to run this again under 98se later tonight so I'll find out what's really going on.
To indulge my curiosity, could you test it in Q3 with the Radeon 7000 and post the results as well? 32FPS at 800x600x32 , more than I thought it would do.
Sure. I'm removing the Matrox stuff as I type this.
