D5CUB PS/2 pinout
First post, by candle_86
I've got a PS2 connector on my board but don't know the pinout manaul lists nothing. Header is
x0xxxx so 5 pin, x's are pins and 0 is no pin. any ideas? Don't want to fry it if i do it wrong
Reply 1 of 2, by TheMobRules
I have that board, though currently it's not in use and I don't have the pinout either. However, by doing some continuity testing with a multimeter I found out that:
 x   0   x   x   x
+5V GND ? ?
So the only thing left would be to determine which of the last two pins is Data and which is Clock.
Reply 2 of 2, by candle_86
Thank you, now my last thing myself to figure out is why it wont hold cmos during a soft reset
