First post, by Gahhhrrrlic
I bought 2 sticks of 256MB CL2 PC133 RAM for my Celeron 700 machine using a VIA Apollo Pro 133 chipset and it's reporting 256MB. I thought ok maybe one of the slots doesn't work so I swapped them around and no change. Then I thought one of the sticks was bad so I tried them separately and they always detect but only at half the amount. So basically it won't see more than half of whatever I put in there. This didn't happen for different RAM, just this RAM. I was disinclined to believe that the RAM was labelled wrong because the modules themselves have a 32 in the code and there are 8 modules so the math works out (8x32 = 256). Plus it's MemoryX and I think they're a pretty good source right?
Anyway could this be the BIOS doing this? Would flashing a newer version help? What do you think?
https://youtu.be/BlBH5VvPXKU
Reply 1 of 11, by cyclone3d
I bet it is a compatibility issue with your motherboard.
It he RAM dual sided or single sided?
What is the exact brand and model number of the sticks?
What motherboard do you have?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 11, by dionb
Yep. If that's an ApolloPro133 (VT693A) chipset, it can handle max 128Mb RAM chips. The ApolloPro133A (VT694X) can do 256Mb chips. I suspect you have 256MB DIMMs with 8 chips. That means 256Mb per chip. If you have a VT693A chipset, only the first 128MB per chip will be used, so you get 256MB total...
Reply 3 of 11, by yawetaG
A BIOS update might help, but it's not guaranteed.
Reply 4 of 11, by gca
Yeah I was going to suggest a BIOS upgrade as well. Had the same problem with an E-Machine with a Trigem Cognac motherboard which only saw 256 of the 512 mb it was supposed to be able to support. Only was to get it sorted was to upgrade the BIOS.
Reply 5 of 11, by Gahhhrrrlic
Hmm... bad on me then for not checking that out first.
The BIOS options do suck so maybe I'll do a flash update anyway and see if it helps. If it doesn't, at least I'll have more overclock options.
Reply 6 of 11, by dionb
You going to tell us exactly which board it is? And how many chips are on the DIMMs in question?
That will at least give an outline of what is possible, only if that all looks good is there much point in flashing the BIOS, at least for this issue.
Reply 7 of 11, by Gahhhrrrlic
Sorry, I thought I mentioned that it was a VIA Apollo Pro 133 and the sticks have 8 ICs on them. Here's the exact page I bought: http://www.memoryx.com/aji.html
Reply 8 of 11, by dionb
Via Apollo Pro 133 is the chipset, not the motherboard, and there's some confusion about it because Via's product page for the 133 contains pictures of the 133A (and neither page lists the relevant memory density info). Hence I want to double-check if it's a 133 or a 133A.
As for the RAM:
Chip - 8pcs 32x8
That's single sided with 256Mb (32x8) chips, just as I suspected. 256Mb is not supported by the Via Apollo Pro 133 (693A) chipset, it can do 128Mb max. If your board really has the 133 not the 133A, then you're not going to be able to use more than half of these DIMMs. For 256MB DIMMs with 693A (or indeed i440BX) you need to get ones with "16pcs 16x8", i.e. double-sided DIMMs with 128Mb chips.
If your board does have a Pro133A (694X) chipset it should be able to handle 256Mb chips in which case a BIOS update might help. But you need to identify the board before contemplating that...
Reply 9 of 11, by Gahhhrrrlic
dionb wrote:
Via Apollo Pro 133 is the chipset, not the motherboard, and there's some confusion about it because Via's product page for the 1 […]
As for the RAM:
Chip - 8pcs 32x8
No, I'm 100% sure it's the 133 without the A. The wiki page said it could support 1.5GB of RAM so I was deceived into thinking that 512MB would be fine. Of course I didn't ask the question about how the chips were configured. I guess these are what's known as "high density" chips? Even so, how can any of the memory be usable? How is the half it sees any different than the half it doesn't? I find it enigmatic.
Reply 10 of 11, by dionb
"High density" is a totally subjective, time-dependent term. In 1998 128Mb chips were high-density. By 2000 they were low-density. Don't take this kind of shortcut, just stick to the density itself. Note that even manufacturers can give incorrect info. Intel claims the i430TX and i440LX chipsets can handle max 64Mb but in fact they are both perfectly capable of accessing 128Mb.
As for only half: it's a matter of addressing. If you have a street with 256 houses but can only use 128 house numbers, the other 128 don't get any post. That's what happening here.
Reply 11 of 11, by Gahhhrrrlic
Thanks for the explanation. Fortunately I went a bit overkill with the RAM, as I doubt it will bottleneck given the CPU speed and the limits that will impose on software. 256 should run just about everything and it's CL2 so I've already maxed everything out in the BIOS for timings - everything is happy.
