First post, by infiniteclouds
I don't know the current state of things over there but in the past GOG has always had a pretty good reputation for adding missing content, additional versions of a game, etc. for titles that they've released.
Has there ever been any collaboration between the collectors here at Vogons who might have rare or difficult to find versions of certain games sold on GOG so that they may be archived and not potentially forever lost to time?
Some examples might be games that had separate Tandy versions or differing re-releases from other publishers - Ultima 2's Sierra vs Origin comes to mind, as one an example
Reply 1 of 13, by leileilol
I haven't seen that. They usually mutilate only the latest releases and slip in wrappers, emulators, and other modifications and present them as fixed modern versions.
FUCK "AI"
Reply 2 of 13, by infiniteclouds
Of course their priority has always been 'run on modern systems' but they have done things after the fact like add the .exe for Indy Last Crusade so it can be run outside of SCUMMVM (though they only have the 256 color .exe available), add the option to download the 1.2v of CotAB (1.3 having title music removed). They've even expanded outside of DOS adding the Macintosh version of Defender of the Crown. I've also seen them add things like Cluebooks to the "Goodies" downloads as well.
I suspect that typically they are happy to add such things but they aren't going to go out of their way to track them down. Usually they are contributed by folks -- which is why I'm asking here.
Reply 3 of 13, by Zup
Some examples of games with multiple versions:
- X-Wing, Tie-Fighter: Once you bought it, you can download the '95 (Windows 95, hi-res, no iMuse), the CD (DOS, hi-res, iMuse) or the floppy (DOS, lo-res, iMuse) version.
- Hotline Miami: You can choose the Windows version or the (demaked?) DOS version.
- Baldur's gate (both): You buy the enhanced version, but can download the original versions.
On the other hand, they always lack on the international versions (i.e: ther was a spanish dubbed version of Stunt Island, I've got the original spanish CDs of X-Wing Alliance). Also, they never hid the fact that their games use emulators, wrappers, fixes or even cracked executables (Re-Volt) to play their games on modern systems. Their goal is allow the users to play their games in modern systems without unnecessary harassment.
At least they give proper credit to the people who created the fixes (DOSBox, etc) and their games work... look at Steam, where you can buy games that maybe won't work on your computer (i.e: Eurofighter Typhoon has troubles even in Windows 7) or won't work at all (i.e.: Insaniquarium, Luxor).
I'm selling some stuff!
Reply 4 of 13, by robertmo
They also often if not always use Qbix's help/consultation/approval with the releases and even pay him for that.
If they care to understand what he says is a different thing though... 😉
Reply 5 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
I helped with a few troublesome games in the past,
but I haven't helped/consulted/approved anything in a very long time.(years)
So calling it "often" is a bit of stretch 😉
Water flows down the stream
Reply 6 of 13, by Qjimbo
The impression I get is that GOG has a harder time with licensing rather than actually obtaining the games files.
Follow me on twitter
Reply 7 of 13, by infiniteclouds
They pulled some pretty impressive magic in acquiring the rights for the SSI titles for themselves.
Reply 8 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
They did awesome stuff for the Ultimas. Scans of the clue books, development notes, original plot stuff etc... and all that came from fans, probably a lot from ghe Origin Museum itself 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 13, by infiniteclouds
Well, I am going to give it a shot by sending them 5.25" disk images of my newly purchased copy of Pools of Radiance -- which they actually own the rights to now. Can anyone suggest a good program for making perfect images of these disks? They use .ARC files and PKUNPAK.
Reply 10 of 13, by DosFreak
I didn't think GOG owned the rights to any games..... They have agreements with the publishers which allow them to distribute the games. If you want to share stuff with GOG then talk to GOG.....
Make your games work offline
Reply 11 of 13, by infiniteclouds
Yes, they have agreements with many publishers but they own the SSI titles.
https://www.pcgamer.com/how-gog-rescued-13-fo … licensing-hell/
With the trail running cold, GOG tracked down SSI’s original President and founder, Joel Billings. “As a huge fan of D&D he was willing to help walk us through a detailed history behind SSI mergers and narrow the search down to two potential candidates: Mattel, or Gores Technology Group (who had acquired The Learning Company). The latter was a hit. We had found the actual rights owners to the Forgotten Realms games, and after several more months of negotiations, they agreed to sell them to us outright.”
Sadly, I've just discovered that my DISK B has errors -- still for future reference I'm interested in recommendations. I've found IMG2DSK to be the most reliable for copying images TO floppies but I'm not sure what program to use to create images off of disks.
Reply 12 of 13, by xjas
Try DDRESCUE if you have a Linux or Mac OSX machine around. It can do magic for reading bad disks.
Reply 13 of 13, by infiniteclouds
It could very well be the 5.25" drive. Disk A did take nearly nearly 30 minutes to unpack all of its contents before the installer prompted Disk B.
