How about a MR-BIOS ROM file repository?
Reply 40 of 442, by Auzner
Thanks for the advice everyone. I will try dumping it again tonight as if it were a 28-pin 27c256:
The attachment Screen Shot 2018-03-22 at 12.36.21 PM.png is no longer available
All these variants of the 28-pin!
The attachment 512.png is no longer available
Reply 43 of 442, by feipoa
And 256kbit was largely for VGA ROM's?
Reply 45 of 442, by appiah4
Just dropping these two MR BIOS manuals here, I harvested them from the eSolutions web site; still poking and trying to find a way to get to the BIOS files 😎
I have a board from 1991 with the MR BIOS on it, would anyone wager a guess as to what the HDD size limitation would be? I'll get a CF card of the according size. I'm thinking of playing it safe and going with 512MB which should be plenty enough for a DX2-66.. But if I can get away with 1 or 2GB, why not?
Reply 46 of 442, by clh333
I have a generic VLB board with a SiS 85C471 chip set . Can anyone say with certainty which of the indexed BIOSes fetaure that chip set?
Thanks for your replies.
-CH-
Reply 47 of 442, by feipoa
512 MB ok for your DX2-66 system? I need at least 2 GB. I use SCSI so the onboard BIOS limit is unimportant.
Reply 48 of 442, by Anonymous Coward
appiah4 wrote:
I am going to build a system with this board sometime in the near future, I will try to dump the bios with uniflash.. […]
For now, please see attached the copies I found of the latest and large HDD patched Mr BIOS bioses.
This board is supposedly based on Headland HT 340 "SHASTA" or possibly Opti 82C802G . Can you confirm which?
Reply 50 of 442, by feipoa
Do you know what the benefits of NSSI copying a BIOS is compared to Uniflash?
Reply 52 of 442, by feipoa
Doesn't uniflash work with most PC BIOSes in the computer?
Reply 53 of 442, by appiah4
It has the Headland chipset.
Reply 55 of 442, by appiah4
Were there other 486 boards that used the HT340 chipset? Do they work with EDRAM as well?
This I do not know I only have experience with this one board.
Reply 56 of 442, by Auzner
Here's the correct binary for the Forex 300 MR BIOS as a 27C512 (64kB as opposed to the 16kB)
The attachment 27c512.PNG is no longer available
Just recently I got several other motherboards so I ordered a USB programmer.
Motherboard photo:
download/file.php?id=42321&mode=view
Reply 58 of 442, by Anonymous Coward
I think I finally tracked down the BIOS image for Macronix 305/306. It's for the Octek Jaguar V. It came from a Russian Hardware Museum site.
http://hwmuseum.pp.ua/index.php?route=hardware&dev=3
I think this image is actually floating around as an attachment on vogons somewhere, but it hasn't been added yet.
