First post, by Bobolaf
Whats your best guess as to what single desktop CPU two Xeon 5080 dual core CPUs equate too in perforce?
Reply 1 of 8, by RichB93
I'd imagine it would be a bit faster than a QX9770.
Reply 2 of 8, by cxm717
The Xeon 5080 use the dempsey core. So probably the same silicon as the presler cores in the Pentium EE 965. These cpus are netburst based so I don't think they would be close to a QX9770, imo
Edit: Depending on your mobo you might be able to upgrade to Xeon 51xx or Xeon 53xx. Which are Woodcrest (same as Conroe) and Kentsfield based
Reply 3 of 8, by agent_x007
So...
Probably better in multithreading apps than Q8200/Q8400*.
I guess max. estimate as on par with Q9400/Q9500 performance (but that is max. for not OC'ed Xeon).
Also, worse in single threaded apps than Core 2 Duo E6600.
Newer stuff is hard to predict (if you asking about Ryzen/*Lake or even Nehalem).
*assuming different-socket communitaction lines won't bottleneck Xeon performance.
Reply 4 of 8, by Bobolaf
Thanks for all the replies. That sounds promising enough that it could possibly play some new ish games. I may build it up and have a go at seeing how well/poorly a netburst systems holds up today.
Reply 5 of 8, by Ozzuneoj
While Passmark isn't the be all end all of benchmarks, this should give you a rough idea since this Pentium Extreme Edition 965 is about the same as one of your Xeon 5080s:
https://www.cpubenchmark.net/compare/Intel-Pe … 132vs2886vs2925
In other words, one CPU has similar per-thread performance to the latest 1.1Ghz 6 Watt Atom-based mobile Pentiums, while scoring far lower in multithreaded benchmarks.
Since the individual cores (not to mention HT) benefit so little from each other, I doubt having two CPUs will bring it anywhere near the performance of even a Core 2 Quad. Would still be interesting to see what it can do though, since this is basically the pinnacle of the pre-Core era.
Prepare for 260 Watts of processing power! 😲
Reply 6 of 8, by agent_x007
At least give Pentium XE 965 a chance.
Here's my Passmark score : LINK
With 5GHz clock 😉
Also P4EE and PXE are NOT the same thing.
Reply 7 of 8, by cxm717
It would be interesting to see what a pair of these will do. Since they are 1066MHz FSB you could try a BSEL mod and run them at 1333. I have a pair of dempsey core Xeons around here somewhere but I'm too lazy to look and they aren't 5080s anyways.
@agent_x007 How much voltage does your 965 need for 1333MHz FSB (with stock multi, I'm guessing its unlocked)?
Reply 8 of 8, by agent_x007
For 4,66GHz I need 1,35-1,4V.
Yes, it's unlocked.
PS. Even that will melt low grade VRM.
