Reply 8920 of 27576, by buckeye
the_ultra_code wrote:
Two things. […]
Two things.
One, added the same StarTech 5.25" 3.5" drive bay into my Pentium 3 machine, just like I did with my P4 machine.
Two, "installed" SoftMPU (i.e. copy the executable file) onto that same machine and created simple batch files to "run" SoftMPU for either my MT-32 Rev.0 or SC-88 (haven't tested the MT-32 with any DOS games on that PC yet, but I know it works with my modern PC playing Dune II via Dune Dynasty 😀 ). Have a really short look at the SC-88 (in SC-55 mapped mode) playing MIDI music in Doom and Doom 2.
The resulting MIDI music is sent from the SC-88 into an audio switch, and then from there into the "line in" port of the AWE64 Value in the system.
Also, question: Does Doom 2 support the SC-88 (with all of its extra sounds), or does it only support the SC-55?
Appreciate your setup. Curious as to what model your Dell monitor is, does it do well generally for DOS games via DVI hookup or you just use VGA?
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 8921 of 27576, by Nvm1
I finally found time to find why my asus 386/33-64k motherboard wouldn't boot completely.
The cyrix fasmath FPU made bad contact between some legs and the socket. Cleaning the legs thoroughly made the board boot again 🤣
Now if only I could find the memory expansion board for it..
Does anybody know if one of the doubleclocked upgrade chips works in the asus 386/33-64k motherboard?
Reply 8922 of 27576, by Murugan
Had to stop my K6-3 build due to missing parts but started 2 Athlon builds 😀 I will pick that one up later on.
I'm having waaaaaay too much hardware 🙁
Reply 8923 of 27576, by GabrielKnight123
I had a motherboard that can take a range of 486 CPU's sitting in the cupboard and tonight was its time for a test if it worked I knew it had a bad leaking battery soldered in so I left it in till I knew it worked so I tried a CPU/Ram/Video card without a case it was just sitting on a table as a test bench and no matter what CPU or ram I tried I could not get even a error code beep, every time I changed the CPU I had to change jumpers I even tried different power supplies I almost gave up when I looked in my spare parts cupboard and I found the exact same motherboard that didn't survive the cleaning process from a leaked battery as well and I found the board I couldn't get working was missing a Bios chip so no wonder nothing worked - palm slap to head - I have now removed the battery, used white vinegar to neutralise anything green and cleaned and got rid of most of the water with a hair dryer and its now air drying.
Reply 8924 of 27576, by ultra_code
Thanks. 😀
Well, that monitor, which I use with both my Pentium 3 and 4 systems, is a Dell 1907FP, which, from what I can tell, is a larger 19" variant of the 17" Dell 1707FP (support page: http://www.dell.com/support/home/us/en/19/pro … 707fpt/research). I got the monitor (along with its original driver CD and an old Pentium 4 Dell PC) from a former teacher when I helped her pull all of her personal files from the Dell PC. While I disassembled the Dell PC and either sold/am selling or threw away its parts, I decided to keep the monitor, and I'm glad I did.
Regarding how I use it, I have it hooked up via VGA to my P3's Voodoo3 3000, and via DVI to my P4's ATI Radeon 9800 Pro 128MB. The monitor has a nice little toggle button on the front of it, so, depending on which retro gaming machine I want to use, I select either "analog" (VGA) or "digital" (DVI), and ta-da!, I can switch between them. 😀
While it's a great Windows monitor, I have used it both in MS-DOS mode and with DOS bootdisks, and it works just fine. I might have to use the auto-adjust sometimes with DOS when using its VGA input, because either the display won't line up with the screen perfectly or sometimes it will be way off, but that works 99.99% of the time. If anything were to need any more fine tuning, though, I could manually adjust settings such as the display's horizontal and vertical positions, as well as settings such as pixel clock and phase (the last two I'm not too familiar with; I know though that I had to work with these settings on this other, I think older, VGA-only Samsung monitor, but it has been such a long time that I forgot exactly how these settings impact the display).
If you want to get one yourself, they seem to sell for around $30-ish on the low-end on ebay, from what I see.
Builds
Reply 8925 of 27576, by oeuvre
    15.19 KiB
Reply 8927 of 27576, by root42
I built a CMOS battery for my 286 mainboard. I put everything on a small board with a diode attached, against charge protection. I used a SAFT 2450mAH Lithium battery at 3.6V. At the 1uA the CMOS draws, I get a voltage drop of about 0.1V to 3.5V. This should be plenty and last for many years.
Todo: I will print a case and attach it with some velcro in the (to be purchased) case.
Picture:
493.87 KiB
1.97 MiB
YouTube video:
https://youtu.be/seCoC2AcHqs
YouTube and Bonus
Reply 8928 of 27576, by oeuvre
voodoo5_6k wrote:
oeuvre wrote:
Ha, finally some good music here 😎
HAMMER SMASHED PENTIUM 4
Reply 8929 of 27576, by appiah4
oeuvre wrote:
Incidentally, the only good Pentium 4.
(AthlonXP forever)
Reply 8930 of 27576, by dionb
(AthlonXP forever)
Cue Guns'n'Roses: crack crack cracking on Athlon's core 😵
(mind you, I ran Athlons back in the day too - P4 was overpriced and overheated - but it was with the Athlon64 X2 and later Core2Duo that things really went into high gear)
Reply 8931 of 27576, by wiretap
Went on my first ever thrift store run. Sadly disappointed, haha. I found a copy of The Sims 2: Pets on PC-CD, and a bunch of 15-17" Dell LCD monitors that were all scratched up. No purchases this time. But it was fun seeing weird stuff that people donate for resale.
My Github
Circuit Board Repair Manuals
Reply 8932 of 27576, by bjwil1991
Wait until fall or winter. You'd be surprised. My thirifting adventures has been slim for a while and some don't take credit cards or their credit card machines are still broken since December. Got a huge haul of computers (2 of them disassembled and in my parts dresser drawer) that needed major work (RAM upgrade, new HDD, new CD-ROM drive), or just minor work (new clock battery, or just a fresh OS install on a perfectly running HDD). PCs I bought at thrift stores (including bidding sites) from 2016-Present:
1) IBM ThinkPad R40 2682 (now has 1GB RAM), Windows XP Pro SP3 32-bit
2) HP Pavilion N3350 (goodwill bidding site), no OS presently (HDD is in my Socket 7 machine using the 2.5" to 3.5" IDE kit)
3) Packard Bell Pack-Mate 28 Plus, MS-DOS 6.22/Windows 95C (only needed a new battery, and installed/upgraded parts)
4) Dell Dimension 4550 (4 bulged up caps, still works), no OS presently
5) Dell Dimension E510 (had Windows 7 Ultimate, DBAN'd the drive, now has linux)
6) iMac G3/600 (HDD went south as well as the CD drive), replaced the HDD with a 200GB one, slim SuperDrive kit, RAM upgraded to 768MB, and replaced PRAM battery, running Mac OS X Tiger 10.4.11 and Lubuntu 16.04.3 LTS
7) HP Pavilion 7955 (parted)*
8 ) 2 Commodore 64 (one needs a new RF modulator or logic board for the A/V out only, the other works great and has an aftermarket case)
9) 2 Dell Inspiron 600m laptops (one has issues, no OS due to HDD issues, the other works without problems, running XP Pro SP3) that need better wireless cards (802.11b isn't functioning any longer)
10) iMac G4/800 (re-installed Mac OS X)
11) HP Pavilion A706N (parted)*
* Kept the internals (motherboard, RAM, CPU, I/O backplane, expansion slot covers, internal cards (modems, wireless cards, USB/FireWire cards), HDD, CD-ROM drives, ribbon cables, PSUs)
Reply 8933 of 27576, by NamelessPlayer
I got all my caps yesterday, and today, I set about recapping that A4000.
Well, it certainly doesn't work any worse than it did before, as far as I can tell, though I'm not sure if it works any better, either. Maybe two of the Fast RAM SIMMs really are suspect enough that I'll have to just run it with the usual 2 MB of Chip RAM and only 8 MB of Fast RAM. Problem is, I don't have any other 72-pin SIMMs lying around.
It's also a painful reminder that I really need some better gear for SMD soldering, because carefully aligning a capacitor to solder it down with a conventional iron gets rather tedious and requires nerves of steel. I'd normally use the hot air blower on the local makerspace's soldering station, but they don't have a PCB pre-heat platform to set the board on, nor do they seem to have any narrower nozzles I can use for this particular purpose.
One of those ultrasonic cleaners would be great too, just to get all the flux and any traces of alkaline electrolyte and battery fluids off that all my isopropyl alcohol scrubbing may have missed.
At the end of the day, though, it's still a working A4000 that keeps its time after I soldered in a CR2032 holder, saved in the nick of time from being another Varta barrel battery victim.
Reply 8934 of 27576, by liqmat
Not computer related, but an incredible find for our family. Found two very early 16mm color movie film reels from the late 1930s while helping my elderly mother clean up her house. I did not realize film reels came in color that early in the 20th century especially home movie reels. My late grandfather filmed all of it apparently and it will be interesting to see what's on them. I checked a few frames under a light and the film looks to be in good condition. Dropping it off tomorrow to get transferred to digital.
422.54 KiB
386.33 KiB
Reply 8935 of 27576, by TheAbandonwareGuy
bjwil1991 wrote:
Wait until fall or winter. You'd be surprised. My thirifting adventures has been slim for a while and some don't take credit car […]
Why on earth would you part out working OEM systems? Those aren't customs builds, they are unique designs that will someday be either uncommon or in the case of alot of obscure models entirely gone. I think HP Pavilions are some of the better looking machines that were produced too.
Reply 8936 of 27576, by TheAbandonwareGuy
My understanding was that no one had developed Kodachrome film since something like 2009?
Reply 8937 of 27576, by ssokolow
Huh. I've got one of those as the right end of the three-monitor spread for my main machine. It was given to me by a friend because the power button had broken and I didn't know how to solvent weld at the time, so I ended up MacGyvering up a solution by...
  1. Drilling a hole over the actual pushbutton
  2. Sawing off the top of a clear push pin
  3. Cutting a shaped piece of electrical tape to hold it in
  4. Using hot glue as a translucent window on the old power button hole.
51.71 KiB
Also, I found another nostalgic, elegant, and useful shell extension in my old DVD+R backups and uploaded it: Something to add the Registry as one of the namespaces in My Computer.
11.61 KiB
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 8938 of 27576, by TheAbandonwareGuy
I'm listening to Van Halen's "5150" on a Dolby HX Pro encoded cassette. This stuff sounds fantastic.
Reply 8939 of 27576, by liqmat
The reel is already developed. I am just going to get it transferred to digital as I don't want to risk sticking this into a projector myself. This probably hasn't been viewed in almost 70 years so I am hoping it hasn't degraded deeper into the reel.
